Ana içeriğe geç
HP Envy 17-3070NR Wireless Card Replacement
Neye ihtiyacın var
  1. HP Envy 17-3070NR Wireless Card Replacement, Back Cover: adım 1, 2 resimden 1. HP Envy 17-3070NR Wireless Card Replacement, Back Cover: adım 1, 2 resimden 2.
    • Before you begin taking apart the computer, make sure that it is completely powered off.
    • Slide the release latch away from the nearest edge.
    • Slide the back cover off of the computer.
  2. HP Envy 17-3070NR Wireless Card Replacement: adım 2, 3 resimden 1. HP Envy 17-3070NR Wireless Card Replacement: adım 2, 3 resimden 2. HP Envy 17-3070NR Wireless Card Replacement: adım 2, 3 resimden 3.
    • Remove the six 3.7mm Phillips screws.
    • Slide the back cover until it clicks, then lift it straight off.
  3. HP Envy 17-3070NR Wireless Card Replacement, Wireless Card: adım 3, 3 resimden 1. HP Envy 17-3070NR Wireless Card Replacement, Wireless Card: adım 3, 3 resimden 2. HP Envy 17-3070NR Wireless Card Replacement, Wireless Card: adım 3, 3 resimden 3.
    • Unscrew 4.5mm Phillips screw.
    • Unplug both antenna connectors by carefully pulling them upwards.
    • During re-assembly make sure to match numbers(1 or 2) on the antenna cable and the wireless card.
  4. HP Envy 17-3070NR Wireless Card Replacement: adım 4, 3 resimden 1. HP Envy 17-3070NR Wireless Card Replacement: adım 4, 3 resimden 2. HP Envy 17-3070NR Wireless Card Replacement: adım 4, 3 resimden 3.
    • Pull wireless card up and away from you.
Sonuç
Jasper Lewin
750 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-8, Amido Spring 2015 Cal Poly, Team 14-8, Amido Spring 2015 üyesi
CPSU-AMIDO-S15S14G8
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 1,089
