Ana içeriğe geç
HP Envy 17-J013CL Battery Replacement
Neye ihtiyacın var
  1. HP Envy 17-J013CL Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Lay the laptop with the battery facing towards you.
    • Remember to disconnect the AC cable and other power sources from the device before replacing/repairing parts.
  2. HP Envy 17-J013CL Battery Replacement: adım 2, 1 resimden 1.
    • Grab hold of the small battery slider and apply pressure to the right.
    • The laptop itself will push the battery out for you once the switch slides all the way to the right.
  3. HP Envy 17-J013CL Battery Replacement: adım 3, 3 resimden 1. HP Envy 17-J013CL Battery Replacement: adım 3, 3 resimden 2. HP Envy 17-J013CL Battery Replacement: adım 3, 3 resimden 3.
    • Pull the battery out and let go of the battery slider.
Sonuç
To reassemble your device, line up the battery and place it down into the metallic prongs for a stable connection.
2 farklı kişi bu kılavuzu tamamladı.
Matt McBride
845 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-6, Blackwell Spring 2017 USF Tampa, Team 16-6, Blackwell Spring 2017 üyesi
USFT-BLACKWELL-S17S16G6
3 Üyeler
Bir Yorum
where does one buy a replacement battery for this HP envy17?
brandondelcastillo - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 17
Her zaman: 1,996
