Ana içeriğe geç
HP Envy 17-J013CL Memory Module Replacement
Neye ihtiyacın var
  1. HP Envy 17-J013CL Memory Module Replacement, Battery: adım 1, 1 resimden 1.
    • Lay the laptop with the battery facing towards you.
    • Remember to disconnect the AC cable and other power sources from the device before replacing/repairing parts.
  2. HP Envy 17-J013CL Memory Module Replacement: adım 2, 1 resimden 1.
    • Grab hold of the small battery slider and apply pressure to the right.
    • The laptop itself will push the battery out for you once the switch slides all the way to the right.
  3. HP Envy 17-J013CL Memory Module Replacement: adım 3, 3 resimden 1. HP Envy 17-J013CL Memory Module Replacement: adım 3, 3 resimden 2. HP Envy 17-J013CL Memory Module Replacement: adım 3, 3 resimden 3.
    • Pull the battery out and let go of the battery slider.
  4. HP Envy 17-J013CL Memory Module Replacement, Back Panel: adım 4, 2 resimden 1. HP Envy 17-J013CL Memory Module Replacement, Back Panel: adım 4, 2 resimden 2.
    • Use a PH1-screwdriver to loosen the 7mm screw. The screw will not fully come out as it is held by a washer underneath but will come out enough to open it.
  5. HP Envy 17-J013CL Memory Module Replacement: adım 5, 1 resimden 1.
    • Gently pull the back panel off starting from the battery side towards the back.
    • Pull it back as it snaps out of the holding sockets.
    • It is preferred to use both hands when pulling the back panel off to prevent bending it out of shape.
  6. HP Envy 17-J013CL Memory Module Replacement, Memory Module: adım 6, 2 resimden 1. HP Envy 17-J013CL Memory Module Replacement, Memory Module: adım 6, 2 resimden 2.
    • Locate the memory stick inside.
  7. HP Envy 17-J013CL Memory Module Replacement: adım 7, 2 resimden 1. HP Envy 17-J013CL Memory Module Replacement: adım 7, 2 resimden 2.
    • On both sides of the module, place a thumb on each of the metallic holding pins.
    • Gently pull on the pins to release the spring holding in the module.
  8. HP Envy 17-J013CL Memory Module Replacement: adım 8, 2 resimden 1. HP Envy 17-J013CL Memory Module Replacement: adım 8, 2 resimden 2.
    • Gently slide the module out of the memory slot.
    • Pay in mind of the module's orientation as it will only go in one way with a little gap in the module to identify orientation.
Sonuç
Matt McBride
845 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-6, Blackwell Spring 2017 USF Tampa, Team 16-6, Blackwell Spring 2017 üyesi
USFT-BLACKWELL-S17S16G6
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 674
