Ana içeriğe geç
HP Envy 17-J013CL Processor Replacement
Neye ihtiyacın var
  1. HP Envy 17-J013CL Processor Replacement, Battery: adım 1, 1 resimden 1.
    • Lay the laptop with the battery facing towards you.
    • Remember to disconnect the AC cable and other power sources from the device before replacing/repairing parts.
  2. HP Envy 17-J013CL Processor Replacement: adım 2, 1 resimden 1.
    • Grab hold of the small battery slider and apply pressure to the right.
    • The laptop itself will push the battery out for you once the switch slides all the way to the right.
  3. HP Envy 17-J013CL Processor Replacement: adım 3, 3 resimden 1. HP Envy 17-J013CL Processor Replacement: adım 3, 3 resimden 2. HP Envy 17-J013CL Processor Replacement: adım 3, 3 resimden 3.
    • Pull the battery out and let go of the battery slider.
  4. HP Envy 17-J013CL Processor Replacement, Back Panel: adım 4, 2 resimden 1. HP Envy 17-J013CL Processor Replacement, Back Panel: adım 4, 2 resimden 2.
    • Use a PH1-screwdriver to loosen the 7mm screw. The screw will not fully come out as it is held by a washer underneath but will come out enough to open it.
  5. HP Envy 17-J013CL Processor Replacement: adım 5, 1 resimden 1.
    • Gently pull the back panel off starting from the battery side towards the back.
    • Pull it back as it snaps out of the holding sockets.
    • It is preferred to use both hands when pulling the back panel off to prevent bending it out of shape.
  6. HP Envy 17-J013CL Processor Replacement, Processor: adım 6, 3 resimden 1. HP Envy 17-J013CL Processor Replacement, Processor: adım 6, 3 resimden 2. HP Envy 17-J013CL Processor Replacement, Processor: adım 6, 3 resimden 3.
    • Locate the 7mm screw for the optical drive right next to the WLAN and Memory modules.
    • Remove the screw with a PH1-screwdriver to release the CD-drive.
  7. HP Envy 17-J013CL Processor Replacement: adım 7, 3 resimden 1. HP Envy 17-J013CL Processor Replacement: adım 7, 3 resimden 2. HP Envy 17-J013CL Processor Replacement: adım 7, 3 resimden 3.
    • Use a PH1-Screwdriver to remove all the 7mm screws.
    • Use a PH0-Screwdriver to remove the 3mm screws.
    • Use the same PH0-Screwdriver for the 2mm screws.
  8. HP Envy 17-J013CL Processor Replacement: adım 8, 2 resimden 1. HP Envy 17-J013CL Processor Replacement: adım 8, 2 resimden 2.
    • Pull the under panel from the laptop by pulling at the edges once all screws are removed. Gently lift it off and place to the side.
  9. HP Envy 17-J013CL Processor Replacement: adım 9, 1 resimden 1.
    • Unscrew the coiled springs indicated in red from the the motherboard.
    • Remove the 7mm screws with a PH1-screwdriver to loosen the fan.
    • Unplug the fan from the motherboard.
  10. HP Envy 17-J013CL Processor Replacement: adım 10, 1 resimden 1.
    • Lift the fan out and then lift out the black grill covering the processor.
  11. HP Envy 17-J013CL Processor Replacement: adım 11, 2 resimden 1. HP Envy 17-J013CL Processor Replacement: adım 11, 2 resimden 2.
    • Use a Flathead screwdriver to turn the screw 180 degrees to unlock the processor from the motherboard.
    • Gently and vertically lift the processor out.
    • When placing the processor chip back in, make sure the golden triangle is on the top-left corner of the motherboard slot.
    • Be careful not to bend the pins on the processor chip. Broken pins will render the chip useless.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Matt McBride
845 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-6, Blackwell Spring 2017 USF Tampa, Team 16-6, Blackwell Spring 2017 üyesi
USFT-BLACKWELL-S17S16G6
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 13
Her zaman: 969
