Ana içeriğe geç
HP Envy 17m-ae111dx Screen Replacement
Neye ihtiyacın var
  1. HP Envy 17m-ae111dx Screen Replacement, Screen: adım 1, 1 resimden 1.
    • Orient your laptop so that the casing is laying on the table and the key board is facing you in the air.
    • If your screen is cracked, use a brush to remove excess glass shards.
  2. HP Envy 17m-ae111dx Screen Replacement: adım 2, 1 resimden 1.
    • In this step, you will melt the adhesive around the outside of the screen.
    • Microwave the iOpener Device for 30 seconds. For more instructions on how to properly use the iOpener, please read through our iOpener instructions.
    • Lay the clear side of the iOpener down on the outer edge of the screen to melt the adhesive.
    • Make sure to wait two minutes before microwaving the iOpener again so as to prevent it from bursting.
  3. HP Envy 17m-ae111dx Screen Replacement: adım 3, 2 resimden 1. HP Envy 17m-ae111dx Screen Replacement: adım 3, 2 resimden 2.
    • Use the iFixit Opening Tool to pry open the screen.
    • Use the iFixit Opening Picks to scrape off the excess glue.
    • Make sure to keep something large wedged between the screen and the cover case to prevent pinching your fingers.
  4. HP Envy 17m-ae111dx Screen Replacement: adım 4, 3 resimden 1. HP Envy 17m-ae111dx Screen Replacement: adım 4, 3 resimden 2. HP Envy 17m-ae111dx Screen Replacement: adım 4, 3 resimden 3.
    • Disconnect the power wire.
    • The power wire is the smaller, black wire in the middle of the screen.
    • Disconnect the display wire.
    • The display wire is the wider cable on the left.
    • Remove the screen from the device.
Sonuç
Bir Yorum
Thanks and by the way this is also equivalent to an hp envy 17-ae013ca
imark7777777 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 17
Her zaman: 1,087
