Ana içeriğe geç
HP Envy 23-d060qd TouchSmart Fan Replacement
Neye ihtiyacın var
  1. HP Envy 23-d060qd TouchSmart Fan Replacement, Back Panel: adım 1, 1 resimden 1.
    • Use your hands to unclip the plastic snaps on the back panel of the device.
  2. HP Envy 23-d060qd TouchSmart Fan Replacement: adım 2, 1 resimden 1.
    • Remove the three 11.5mm PH2 screws from the back panel.
    • The screws will not fall out of the back panel, but they will unscrew to release the back panel.
  3. HP Envy 23-d060qd TouchSmart Fan Replacement: adım 3, 1 resimden 1.
    • Now, take the back panel off by pulling at it gently with your hands.
  4. HP Envy 23-d060qd TouchSmart Fan Replacement, Fan: adım 4, 2 resimden 1. HP Envy 23-d060qd TouchSmart Fan Replacement, Fan: adım 4, 2 resimden 2.
    • Remove the five 7.5mm T15 screws from the cover plate.
    • Remove the cover plate.
  5. HP Envy 23-d060qd TouchSmart Fan Replacement: adım 5, 2 resimden 1. HP Envy 23-d060qd TouchSmart Fan Replacement: adım 5, 2 resimden 2.
    • Use your hands to separate the fan's wired connection to the motherboard. Use your hands to gently pull the plastic piece at the ends of the wires.
    • Be gentle when you separate wired connections. Pulling on the wires can damage them.
  6. HP Envy 23-d060qd TouchSmart Fan Replacement: adım 6, 1 resimden 1.
    • Remove the three 8mm T15 screws from the fan.
  7. HP Envy 23-d060qd TouchSmart Fan Replacement: adım 7, 1 resimden 1.
    • Pull the fan loose from the computer.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Zachary Dicks
1.117 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-10, Maness Fall 2015 Cal Poly, Team 5-10, Maness Fall 2015 üyesi
CPSU-MANESS-F15S5G10
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 19
Her zaman: 3,653
