Ana içeriğe geç
HP Envy 23-d060qd TouchSmart RAM Replacement
Neye ihtiyacın var
  1. HP Envy 23-d060qd TouchSmart RAM Replacement, Back Panel: adım 1, 1 resimden 1.
    • Use your hands to unclip the plastic snaps on the back panel of the device.
  2. HP Envy 23-d060qd TouchSmart RAM Replacement: adım 2, 1 resimden 1.
    • Remove the three 11.5mm PH2 screws from the back panel.
    • The screws will not fall out of the back panel, but they will unscrew to release the back panel.
  3. HP Envy 23-d060qd TouchSmart RAM Replacement: adım 3, 1 resimden 1.
    • Now, take the back panel off by pulling at it gently with your hands.
  4. HP Envy 23-d060qd TouchSmart RAM Replacement, RAM: adım 4, 2 resimden 1. HP Envy 23-d060qd TouchSmart RAM Replacement, RAM: adım 4, 2 resimden 2.
    • Pop off the easy-access cover to get into the RAM module.
  5. HP Envy 23-d060qd TouchSmart RAM Replacement: adım 5, 2 resimden 1. HP Envy 23-d060qd TouchSmart RAM Replacement: adım 5, 2 resimden 2.
    • Push out the four clips that hold the RAM modules to the side.
    • The RAM modules will pop open after you unclick all four clips.
  6. HP Envy 23-d060qd TouchSmart RAM Replacement: adım 6, 1 resimden 1.
    • Pull out each module.
    • Replace RAM with desired replacement.
    • When substituting your RAM in, make sure to line up the edges with the lines on the RAM compartment so that the RAM is able to fit inside properly.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Zachary Dicks
1.117 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-10, Maness Fall 2015 Cal Poly, Team 5-10, Maness Fall 2015 üyesi
CPSU-MANESS-F15S5G10
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 21
Her zaman: 3,214
