Ana içeriğe geç
HP Envy 4-1030us Battery Replacement
Neye ihtiyacın var
  1. HP Envy 4-1030us Battery Replacement, Bottom Cover: adım 1, 2 resimden 1. HP Envy 4-1030us Battery Replacement, Bottom Cover: adım 1, 2 resimden 2.
    • Using the Philips #0 screwdriver, remove the 12 7.5mm screws from the bottom cover.
  2. HP Envy 4-1030us Battery Replacement: adım 2, 2 resimden 1. HP Envy 4-1030us Battery Replacement: adım 2, 2 resimden 2.
    • Using the plastic opening tool, carefully work the tool between the bottom cover and bottom chassis to loosen the connection.
    • Lift the bottom cover off of the system.
  3. HP Envy 4-1030us Battery Replacement, Battery: adım 3, 2 resimden 1. HP Envy 4-1030us Battery Replacement, Battery: adım 3, 2 resimden 2.
    • Disconnect the battery cable from the motherboard. This will be found above the battery and below the CPU fan.
    • To take the cable out, carefully grab the head of the cable and slowly pull it outwards.
  4. HP Envy 4-1030us Battery Replacement: adım 4, 2 resimden 1. HP Envy 4-1030us Battery Replacement: adım 4, 2 resimden 2.
    • Use the Philips #0 screwdriver to remove the three 4.2mm screws that are securing the battery to the board.
  5. HP Envy 4-1030us Battery Replacement: adım 5, 2 resimden 1. HP Envy 4-1030us Battery Replacement: adım 5, 2 resimden 2.
    • Then slowly remove the battery from the right side of the battery and then raise it up.
    • Make sure to move the USB Audio board cable away from the battery incase it gets caught.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Christopher Luna
700 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G1, Thompson Fall 2017 USF Tampa, Team S1-G1, Thompson Fall 2017 üyesi
USFT-THOMPSON-F17S1G1
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 947
