Ana içeriğe geç
HP Envy 4-1030us Hard Drive Replacement
Neye ihtiyacın var
  1. HP Envy 4-1030us Hard Drive Replacement, Bottom Cover: adım 1, 2 resimden 1. HP Envy 4-1030us Hard Drive Replacement, Bottom Cover: adım 1, 2 resimden 2.
    • Using the Philips #0 screwdriver, remove the 12 7.5mm screws from the bottom cover.
  2. HP Envy 4-1030us Hard Drive Replacement: adım 2, 2 resimden 1. HP Envy 4-1030us Hard Drive Replacement: adım 2, 2 resimden 2.
    • Using the plastic opening tool, carefully work the tool between the bottom cover and bottom chassis to loosen the connection.
    • Lift the bottom cover off of the system.
  3. HP Envy 4-1030us Hard Drive Replacement, Hard Drive: adım 3, 1 resimden 1.
    • After removing the cover the mSATA SSD should be visible near the center of the device.
    • Remove the one Phillips 2.5mm screw holding the SSD in place. The drive should pop up after removing the screw.
  4. HP Envy 4-1030us Hard Drive Replacement: adım 4, 1 resimden 1.
    • To remove the SSD grab the edges and pull it from the slot.
    • Try not to touch any pins or connectors. Damaged pins could result in permanent damage to the system.
Sonuç
Christopher Luna
700 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G1, Thompson Fall 2017 USF Tampa, Team S1-G1, Thompson Fall 2017 üyesi
USFT-THOMPSON-F17S1G1
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 844
