Ana içeriğe geç
HP Envy 4-1030us Wireless Card Replacement
Neye ihtiyacın var
  1. HP Envy 4-1030us Wireless Card Replacement, Bottom Cover: adım 1, 2 resimden 1. HP Envy 4-1030us Wireless Card Replacement, Bottom Cover: adım 1, 2 resimden 2.
    • Using the Philips #0 screwdriver, remove the 12 7.5mm screws from the bottom cover.
  2. HP Envy 4-1030us Wireless Card Replacement: adım 2, 2 resimden 1. HP Envy 4-1030us Wireless Card Replacement: adım 2, 2 resimden 2.
    • Using the plastic opening tool, carefully work the tool between the bottom cover and bottom chassis to loosen the connection.
    • Lift the bottom cover off of the system.
  3. HP Envy 4-1030us Wireless Card Replacement, Wireless Card: adım 3, 2 resimden 1. HP Envy 4-1030us Wireless Card Replacement, Wireless Card: adım 3, 2 resimden 2.
    • After removing the bottom cover, the wireless card is accessible toward the rear of the system.
    • The wireless card may be underneath a piece or layer of black protective electrical tape. Carefully peel back the tape to access the card.
  4. HP Envy 4-1030us Wireless Card Replacement: adım 4, 2 resimden 1. HP Envy 4-1030us Wireless Card Replacement: adım 4, 2 resimden 2.
    • Disconnect the wires from the wireless card by lifting them up from the metal studs they are set on.
    • The wires are not screwed onto the studs, but may still require some wiggling or twisting to help them come off.
  5. HP Envy 4-1030us Wireless Card Replacement: adım 5, 1 resimden 1.
    • Using the Phillips #0 screwdriver unscrew the single 2.5mm screw holding the card to the motherboard.
  6. HP Envy 4-1030us Wireless Card Replacement: adım 6, 1 resimden 1.
    • Slide the card out of it's connector.
    • After removing the screw, the card will lift at an angle in its connector.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Christopher Luna
700 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G1, Thompson Fall 2017 USF Tampa, Team S1-G1, Thompson Fall 2017 üyesi
USFT-THOMPSON-F17S1G1
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 224
