Ana içeriğe geç
HP Envy 4-1105dx Keyboard Replacement
Neye ihtiyacın var
    1. HP Envy 4-1105dx Keyboard Replacement, Battery: adım 1, 1 resimden 1.
      • Power off the device before beginning disassembly. Disconnect all external devices.
      • Flip the device on its back.
      FixBot'a Sor
      Yorum Ekle
    2. HP Envy 4-1105dx Keyboard Replacement: adım 2, 1 resimden 1.
      • Unscrew and remove the one 7.5 mm Phillips-head screw using Phillips #1 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. HP Envy 4-1105dx Keyboard Replacement: adım 3, 1 resimden 1.
      • Unscrew twelve 6.0 mm Phillips-head screws using Phillips #1 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    4. HP Envy 4-1105dx Keyboard Replacement: adım 4, 1 resimden 1.
      • Use the plastic opening tool (which is short and has a thin end for prying open device parts) to pry open the back case of the device.
      FixBot'a Sor
      Yorum Ekle
    5. HP Envy 4-1105dx Keyboard Replacement: adım 5, 1 resimden 1.
      • Once the device is open, move the ribbon cable to the side.
      FixBot'a Sor
      Yorum Ekle
    6. HP Envy 4-1105dx Keyboard Replacement: adım 6, 1 resimden 1.
      • Use the flat end of a plastic spudger to disconnect the battery cable from its socket in the motherboard.
      FixBot'a Sor
      Yorum Ekle
    7. HP Envy 4-1105dx Keyboard Replacement: adım 7, 1 resimden 1.
      • Unscrew and remove the three 4.0 mm Phillips-head screws that hold the battery in place, using a Phillips #1 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    8. HP Envy 4-1105dx Keyboard Replacement: adım 8, 1 resimden 1.
      • Lift the battery up and remove.
      • Removing the battery can dislodge the touchpad bracket. Place the battery carefully over the alignment pins.
      FixBot'a Sor
      Yorum Ekle
    1. HP Envy 4-1105dx Keyboard Replacement, Hard Drive: adım 9, 2 resimden 1. HP Envy 4-1105dx Keyboard Replacement, Hard Drive: adım 9, 2 resimden 2.
      • Remove the four 4.0 mm screws that hold down the hard drive case using a Philips #1 Screwdriver.
      • Move the hard drive case and hard drive so that you can easily reach the hard drive cable.
      FixBot'a Sor
      Yorum Ekle
    2. HP Envy 4-1105dx Keyboard Replacement: adım 10, 3 resimden 1. HP Envy 4-1105dx Keyboard Replacement: adım 10, 3 resimden 2. HP Envy 4-1105dx Keyboard Replacement: adım 10, 3 resimden 3.
      • Use the plastic spudger tool to loosen the hard drive SATA cable connection by pushing it away from the motherboard.
      • Once it is loose, pull the hard drive out of the socket.
      • Remove the hard drive from the device.
      FixBot'a Sor
      Yorum Ekle
    3. HP Envy 4-1105dx Keyboard Replacement: adım 11, 3 resimden 1. HP Envy 4-1105dx Keyboard Replacement: adım 11, 3 resimden 2. HP Envy 4-1105dx Keyboard Replacement: adım 11, 3 resimden 3.
      • Pull out the hard drive cable from the hard drive, and set it aside.
      • Remove the four 3.0 mm screws that attach the hard drive case to the hard drive using a Philips #1 Screwdriver. If the screwdriver is too big, try #0 sized screwdriver.
      FixBot'a Sor
      Yorum Ekle
    4. HP Envy 4-1105dx Keyboard Replacement: adım 12, 1 resimden 1.
      • Remove the hard drive from the hard drive case.
      FixBot'a Sor
      Yorum Ekle
    1. HP Envy 4-1105dx Keyboard Replacement, Motherboard: adım 13, 1 resimden 1.
      • Prepare to disconnect the motherboard from any components you have not already removed, including the screen, touchpad, and keyboard.
      • In its original factory configuration, the motherboard is connected to 10 components.
      • Take notes or photographs to help you remember which connections went to which components.
      • Components do not have to be disconnected in the order shown.
      • Whenever possible, use plastic tools rather than metal ones, and don't touch connection points.
      FixBot'a Sor
      Yorum Ekle
    2. HP Envy 4-1105dx Keyboard Replacement: adım 14, 2 resimden 1. HP Envy 4-1105dx Keyboard Replacement: adım 14, 2 resimden 2.
      • Remove the ribbon cable running from under the motherboard by undoing the latch mechanism with your fingernail, and pulling out on the edge of the connector. (This is the keyboard cable).
      FixBot'a Sor
      Yorum Ekle
    3. HP Envy 4-1105dx Keyboard Replacement: adım 15, 2 resimden 1. HP Envy 4-1105dx Keyboard Replacement: adım 15, 2 resimden 2.
      • Flip up the black connector with your fingernail or using the plastic spudger.
      • Unplug the trackpad by pulling up on the touchpad board cable.
      FixBot'a Sor
      Yorum Ekle
    4. HP Envy 4-1105dx Keyboard Replacement: adım 16, 2 resimden 1. HP Envy 4-1105dx Keyboard Replacement: adım 16, 2 resimden 2.
      • Use the plastic spudger to gently pry out the small chip next to the touchpad.
      • The metal spudger has been used in the photograph, but the plastic spudger is a better choice because it is ESD safe.
      FixBot'a Sor
      Yorum Ekle
    5. HP Envy 4-1105dx Keyboard Replacement: adım 17, 2 resimden 1. HP Envy 4-1105dx Keyboard Replacement: adım 17, 2 resimden 2.
      • Disconnect the ribbon cable running to the ports on the right-hand side of the laptop.
      FixBot'a Sor
      Yorum Ekle
    6. HP Envy 4-1105dx Keyboard Replacement: adım 18, 3 resimden 1. HP Envy 4-1105dx Keyboard Replacement: adım 18, 3 resimden 2. HP Envy 4-1105dx Keyboard Replacement: adım 18, 3 resimden 3.
      • Disconnect the two small ribbon cables in front of the hard drive. The larger one is the touchpad board cable, and the smaller one is the keyboard light cable.
      FixBot'a Sor
      Yorum Ekle
    7. HP Envy 4-1105dx Keyboard Replacement: adım 19, 2 resimden 1. HP Envy 4-1105dx Keyboard Replacement: adım 19, 2 resimden 2.
      • Using a Phillips #0 screwdriver, remove the two 3.0 mm screws holding the speaker and motherboard to the plastic frame.
      • Move the speaker out of the way. It will stay attached to the motherboard. The cord connection cannot be disconnected.
      FixBot'a Sor
      Yorum Ekle
    8. HP Envy 4-1105dx Keyboard Replacement: adım 20, 1 resimden 1.
      • Pull back the black plastic covering over the northbridge.
      FixBot'a Sor
      Yorum Ekle
    9. HP Envy 4-1105dx Keyboard Replacement: adım 21, 2 resimden 1. HP Envy 4-1105dx Keyboard Replacement: adım 21, 2 resimden 2.
      • Using a Phillips #0 screwdriver, remove the 3.0 mm screw securing the wireless LAN adapter.
      • Detach the wireless LAN adapter from the board.
      FixBot'a Sor
      Yorum Ekle
    10. HP Envy 4-1105dx Keyboard Replacement: adım 22, 2 resimden 1. HP Envy 4-1105dx Keyboard Replacement: adım 22, 2 resimden 2.
      • Using your fingers, locate the display panel cable under the hinge and disconnect it.
      FixBot'a Sor
      Yorum Ekle
    11. HP Envy 4-1105dx Keyboard Replacement: adım 23, 2 resimden 1. HP Envy 4-1105dx Keyboard Replacement: adım 23, 2 resimden 2.
      • Disconnect the multicolored power connector for the USB/audio board by first probing it gently with a plastic spudger, then pulling it free.
      FixBot'a Sor
      Yorum Ekle
    12. HP Envy 4-1105dx Keyboard Replacement: adım 24, 2 resimden 1. HP Envy 4-1105dx Keyboard Replacement: adım 24, 2 resimden 2.
      • Disconnect the red and black power connector for the subwoofer by first probing it gently with a plastic spudger, then pulling it free with your fingernails.
      FixBot'a Sor
      Yorum Ekle
    13. HP Envy 4-1105dx Keyboard Replacement: adım 25, 3 resimden 1. HP Envy 4-1105dx Keyboard Replacement: adım 25, 3 resimden 2. HP Envy 4-1105dx Keyboard Replacement: adım 25, 3 resimden 3.
      • Peel back more of the black plastic to reveal the multicolored power connector for the cooling fan.
      • Disconnect the power connector for the cooling fan by probing it with the spudger, then pulling it free.
      FixBot'a Sor
      Yorum Ekle
    14. HP Envy 4-1105dx Keyboard Replacement: adım 26, 2 resimden 1. HP Envy 4-1105dx Keyboard Replacement: adım 26, 2 resimden 2.
      • Using a Phillips #0 screwdriver, remove the two 2.0 mm screws holding the right speaker in place.
      • Remove the right speaker.
      FixBot'a Sor
      Yorum Ekle
    15. HP Envy 4-1105dx Keyboard Replacement: adım 27, 2 resimden 1. HP Envy 4-1105dx Keyboard Replacement: adım 27, 2 resimden 2.
      • Using a Phillips #0 screwdriver, remove the 2.5 mm screw holding the cooling fan in place.
      • Lift out the cooling fan.
      FixBot'a Sor
      Yorum Ekle
    16. HP Envy 4-1105dx Keyboard Replacement: adım 28, 2 resimden 1. HP Envy 4-1105dx Keyboard Replacement: adım 28, 2 resimden 2.
      • Using the plastic spudger, remove the power button cable. This is the small, purple ribbon cable at the back of the motherboard.
      FixBot'a Sor
      Yorum Ekle
    17. HP Envy 4-1105dx Keyboard Replacement: adım 29, 3 resimden 1. HP Envy 4-1105dx Keyboard Replacement: adım 29, 3 resimden 2. HP Envy 4-1105dx Keyboard Replacement: adım 29, 3 resimden 3.
      • Using a Phillips #0 screwdriver, remove any remaining screws attaching the motherboard to the rest of the laptop.
      FixBot'a Sor
      Yorum Ekle
    18. HP Envy 4-1105dx Keyboard Replacement: adım 30, 2 resimden 1. HP Envy 4-1105dx Keyboard Replacement: adım 30, 2 resimden 2.
      • Gently lift out the motherboard and heat sink. If the motherboard has been fully disconnected from other components, it will lift free easily.
      • If the motherboard seems stuck, do not force it. Instead, return to previous steps to see if there is a connection or screw you have missed. Also check for tape, glue, or similar materials that may be attached to the motherboard.
      • Removing the motherboard before it has been fully disconnected may break not only the old motherboard, but connections or components that you will need to attach to the new motherboard. Do not rush this step.
      FixBot'a Sor
      Yorum Ekle
    1. HP Envy 4-1105dx Keyboard Replacement, Keyboard: adım 31, 3 resimden 1. HP Envy 4-1105dx Keyboard Replacement, Keyboard: adım 31, 3 resimden 2. HP Envy 4-1105dx Keyboard Replacement, Keyboard: adım 31, 3 resimden 3.
      • Unscrew the two 3 mm screws from the 2 silver metal hinges using a Philips #1 Screwdriver.
      • Unscrew the two 2.5 mm screws from the black metal anti-theft locking component using a Philips #1 Screwdriver.
      • Unscrew the two 3.0 mm screws from the silver metal port using a Philips #1 Screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. HP Envy 4-1105dx Keyboard Replacement: adım 32, 3 resimden 1. HP Envy 4-1105dx Keyboard Replacement: adım 32, 3 resimden 2. HP Envy 4-1105dx Keyboard Replacement: adım 32, 3 resimden 3.
      • Unscrew the 2 3.0 mm screws holding the chip with the multiple ports using a Philips #1 Screwdriver.
      • Move the chip with multiple ports to the side.
      • Use your fingers or a plastic or metal spudger tool to start prying up the metal case to reveal the keyboard.
      FixBot'a Sor
      Yorum Ekle
    3. HP Envy 4-1105dx Keyboard Replacement: adım 33, 3 resimden 1. HP Envy 4-1105dx Keyboard Replacement: adım 33, 3 resimden 2. HP Envy 4-1105dx Keyboard Replacement: adım 33, 3 resimden 3.
      • Separate the metal case from the keyboard by peeling off the tape that connects them.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
KC Armstrong
204 İtibar
2 adet Kılavuz yazıldı
3Kılavuz Yorumları
Thanks for the guide, it help me a lot with an other Hp Envy 14 model.
Nice mate
Pablo Tassinari - Yanıt Paylaş
What technique is used on step 4 to remove the bottom? I need to remove mine but want to be careful not to break tabs or damage the edge.
Seems no one highlights this… its always unscrew then magically they show it with the bottom off.
Neccros - Yanıt Paylaş
Hi Neccros,
It has been a while since I have performed that procedure (step 4). However, I remember that I used the plastic prying tool to loosen as many parts of the bottom that I could before using my hands. I don’t remember it being easy to damage the bottom as long as you loosen each part slowly and then pull with your hands slowly. If you feel too much resistance, stop prying and double-check you have removed all screws. I also recommend watching a youtube video where someone takes a laptop apart. That might help you visualize the process before you start. Best of luck!
KC Armstrong - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 22
Her zaman: 3,993
