Giriş
Replacing the keyboard may be necessary if the keyboard becomes nonresponsive. In order to reach the keyboard, you will have to remove the battery, hard drive, and motherboard first.
Neye ihtiyacın var
Remove the four 4.0 mm screws that hold down the hard drive case using a Philips #1 Screwdriver.
Move the hard drive case and hard drive so that you can easily reach the hard drive cable.
Prepare to disconnect the motherboard from any components you have not already removed, including the screen, touchpad, and keyboard.
Gently lift out the motherboard and heat sink. If the motherboard has been fully disconnected from other components, it will lift free easily.
If the motherboard seems stuck, do not force it. Instead, return to previous steps to see if there is a connection or screw you have missed. Also check for tape, glue, or similar materials that may be attached to the motherboard.
Unscrew the two 3 mm screws from the 2 silver metal hinges using a Philips #1 Screwdriver.
Unscrew the two 2.5 mm screws from the black metal anti-theft locking component using a Philips #1 Screwdriver.
Unscrew the two 3.0 mm screws from the silver metal port using a Philips #1 Screwdriver.
3 farklı kişi bu kılavuzu tamamladı.
3 Yorum
Thanks for the guide, it help me a lot with an other Hp Envy 14 model.
Nice mate
What technique is used on step 4 to remove the bottom? I need to remove mine but want to be careful not to break tabs or damage the edge.
Seems no one highlights this… its always unscrew then magically they show it with the bottom off.
Hi Neccros,
It has been a while since I have performed that procedure (step 4). However, I remember that I used the plastic prying tool to loosen as many parts of the bottom that I could before using my hands. I don’t remember it being easy to damage the bottom as long as you loosen each part slowly and then pull with your hands slowly. If you feel too much resistance, stop prying and double-check you have removed all screws. I also recommend watching a youtube video where someone takes a laptop apart. That might help you visualize the process before you start. Best of luck!
