Ana içeriğe geç
HP Envy 4520 AC Adapter Replacement
Neye ihtiyacın var
  1. HP Envy 4520 AC Adapter Replacement, AC Adapter: adım 1, 1 resimden 1.
    • Ensure that the printer is turned off.
    • Locate and remove the black power cord from the back of the printer.
  2. HP Envy 4520 AC Adapter Replacement: adım 2, 2 resimden 1. HP Envy 4520 AC Adapter Replacement: adım 2, 2 resimden 2.
    • Lift the top of the printer.
    • Using the plastic opening tool, remove the clip holding the scanner bed up by prying the clip away from the the side of the scanner bed.
  3. HP Envy 4520 AC Adapter Replacement: adım 3, 3 resimden 1. HP Envy 4520 AC Adapter Replacement: adım 3, 3 resimden 2. HP Envy 4520 AC Adapter Replacement: adım 3, 3 resimden 3.
    • Remove the six 14 mm T10 Hex screws.
    • Pry the plastic cover off using the blue opening tool.
  4. HP Envy 4520 AC Adapter Replacement: adım 4, 2 resimden 1. HP Envy 4520 AC Adapter Replacement: adım 4, 2 resimden 2.
    • Locate the the AC adapter at the top left corner of the device which is connected by intertwined red and blue wires.
  5. HP Envy 4520 AC Adapter Replacement: adım 5, 3 resimden 1. HP Envy 4520 AC Adapter Replacement: adım 5, 3 resimden 2. HP Envy 4520 AC Adapter Replacement: adım 5, 3 resimden 3.
    • Remove the adapter by pinching the plastic head of the wire connector and pulling it out of the port.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
Forgot a step at the beginning. Have to remove the inside clip connected to the lid. If you only remove the outside clip in step 2 and not the inside clip, it will snap. This clip triggers the cartridges to slide to the left when the lid is open for replacement.
harmspjf harmspjf - Yanıt
Where is this "Inside Clip" located, and how do you do you remove it?
azbobcat - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 47
Her zaman: 1,589
