Giriş
This guide will show you how to replace the glass scanner bed.
Neye ihtiyacın var
Remove the large flat ribbon cable by pinching the top and bottom of the cable between thumb and index finger and pulling away from the mother board.
Remove the small flat ribbon cable by pinching the top and bottom of the cable between thumb and index finger and pulling away from the mother board.
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
step 4 - Remove the clip holding the scanner bed up by using the plastic opening tools. Prying the clip away from the the side of the scanner bed.
That clip is designed to be pulled toward the front of the printer to be released from the pin. And push the arm toward the back to snap back in place.
