Ana içeriğe geç
HP Envy 5660 LCD Replacement
Neye ihtiyacın var
  1. HP Envy 5660 LCD Replacement, LCD: adım 1, 1 resimden 1.
    • Lift the scanner to open up the printer cartridge access area.
  2. HP Envy 5660 LCD Replacement: adım 2, 2 resimden 1. HP Envy 5660 LCD Replacement: adım 2, 2 resimden 2.
    • Remove the two 12 mm screws with a T10 bit.
  3. HP Envy 5660 LCD Replacement: adım 3, 3 resimden 1. HP Envy 5660 LCD Replacement: adım 3, 3 resimden 2. HP Envy 5660 LCD Replacement: adım 3, 3 resimden 3.
    • Use a metal spudger to pry open the front panel.
    • Work your way all the way around the front panel doing the same.
    • Gently flip the cover over, exposing the motherboard.
    • There will be loud popping sounds when the cover is being separated from the rest of the printer.
  4. HP Envy 5660 LCD Replacement: adım 4, 2 resimden 1. HP Envy 5660 LCD Replacement: adım 4, 2 resimden 2.
    • Remove the four 4.5 mm screws from the motherboard with a T6 bit.
    • Gently remove the motherboard from the top of the LCD, but make sure the ribbon cables are still attached.
    • Beware damaging the white ribbon cable.
  5. HP Envy 5660 LCD Replacement: adım 5, 2 resimden 1. HP Envy 5660 LCD Replacement: adım 5, 2 resimden 2.
    • Remove the four 5 mm screws with a T6 bit, allowing you to separate the LCD from the cover,
  6. HP Envy 5660 LCD Replacement: adım 6, 1 resimden 1.
    • Place the metal spudger underneath the LCD and gently lift up to remove the LCD.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ryan Steakley
781 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G6, Livingston Winter 2018 Cal Poly, Team S1-G6, Livingston Winter 2018 üyesi
CPSU-LIVINGSTON-W18S1G6
4 Üyeler
10 adet Kılavuz yazıldı
2 Yorum
Great description but there is a part needed - the LCD. Is that part available? How do I get it?
Thanks,
PJE
pateckelberry - Yanıt
Ditto, I'm in the same position, did you ever find the part/LCD replacement screen?
Tessa Robles - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 18
Her zaman: 1,242
