Ana içeriğe geç
HP Envy 5660 Scanner Glass Replacement
Neye ihtiyacın var
    1. HP Envy 5660 Scanner Glass Replacement, Scanner Glass: adım 1, 1 resimden 1.
      • Open the cartridge access area.
      FixBot'a Sor
      Yorum Ekle
    2. HP Envy 5660 Scanner Glass Replacement: adım 2, 1 resimden 1.
      • Remove the three 11.5 mm screws with a T10 bit.
      FixBot'a Sor
      Yorum Ekle
    3. HP Envy 5660 Scanner Glass Replacement: adım 3, 3 resimden 1. HP Envy 5660 Scanner Glass Replacement: adım 3, 3 resimden 2. HP Envy 5660 Scanner Glass Replacement: adım 3, 3 resimden 3.
      • Locate the cover hinge on the right side of the printer.
      • Pull the hinge off of the scanner to allow the scanner to open to 90 degress.
      FixBot'a Sor
      Yorum Ekle
    4. HP Envy 5660 Scanner Glass Replacement: adım 4, 2 resimden 1. HP Envy 5660 Scanner Glass Replacement: adım 4, 2 resimden 2.
      • Remove the 12 mm screws on the left side of the printer with a T10 bit.
      FixBot'a Sor
      Yorum Ekle
    5. HP Envy 5660 Scanner Glass Replacement: adım 5, 2 resimden 1. HP Envy 5660 Scanner Glass Replacement: adım 5, 2 resimden 2.
      • Remove the 11.5 mm screw with a T10 bit to release the spring-loaded hinge.
      • Since this is a compression spring, the hinge will snap downwards as soon as it is loosened.
      FixBot'a Sor
      Yorum Ekle
    6. HP Envy 5660 Scanner Glass Replacement: adım 6, 3 resimden 1. HP Envy 5660 Scanner Glass Replacement: adım 6, 3 resimden 2. HP Envy 5660 Scanner Glass Replacement: adım 6, 3 resimden 3.
      • Pull the plastic side cover off of the printer.
      • You may need to lift the printer and push the cover downwards as it is latched onto the bottom of the printer.
      • Plastic opening tools or a metal spudger may also be used.
      FixBot'a Sor
      Yorum Ekle
    7. HP Envy 5660 Scanner Glass Replacement: adım 7, 1 resimden 1.
      • Remove the five 11.5 mm screws located at the bottom of the scanner.
      • Steps 3-6 were intended to create easier access to these screws. However, they will still be difficult to reach.
      • The top of the scanner will now easily pull off.
      FixBot'a Sor
      Yorum Ekle
    8. HP Envy 5660 Scanner Glass Replacement: adım 8, 2 resimden 1. HP Envy 5660 Scanner Glass Replacement: adım 8, 2 resimden 2.
      • Pry the old scanning glass up with a metal spudger.
      • There are adhesives under the scanning glass. Be careful not to break the glass while removing it.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Ryan Steakley
790 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G6, Livingston Winter 2018 Cal Poly, Team S1-G6, Livingston Winter 2018 üyesi
CPSU-LIVINGSTON-W18S1G6
4 Üyeler
10 adet Kılavuz yazıldı
1Rehber Yorum
Remove an additional three 11.5 mm torx head screws in the same plane as step #4 photo, but near the hinges. This allows the cover hinges to be raised a bit for easier access to the screws removed in step #7. It also makes it easier to remove and reinstall the side cover.
My scanner glass was not broken, but inside surface had a dirty haze that was effecting my scans and needed cleaning. Thanks, I was ready to buy a new scanner.
Rich Monell - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 23
Her zaman: 2,022
