Ana içeriğe geç
HP Envy 700-030qe CD Drive Replacement
Neye ihtiyacın var
    1. HP Envy 700-030qe CD Drive Replacement, CD Drive: adım 1, 2 resimden 1. HP Envy 700-030qe CD Drive Replacement, CD Drive: adım 1, 2 resimden 2.
      • Make sure that you are wearing your anti-static wristband. This will prevent damaging any internal parts with any built up static electricity.
      • Unscrew the 10.5mm screw on the left of the desktop using your hand.
      • If it is too tight you may use a torx-head screwdriver or a flat-head screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. HP Envy 700-030qe CD Drive Replacement: adım 2, 2 resimden 1. HP Envy 700-030qe CD Drive Replacement: adım 2, 2 resimden 2.
      • Remove the side panel by sliding it towards the back of the desktop and pulling up on it as shown.
      FixBot'a Sor
      Yorum Ekle
    3. HP Envy 700-030qe CD Drive Replacement: adım 3, 1 resimden 1.
      • For the next step, remove the CD drive power cable.
      FixBot'a Sor
      Yorum Ekle
    4. HP Envy 700-030qe CD Drive Replacement: adım 4, 1 resimden 1.
      • Reorient the device with the front pointing away from you.
      • Next, remove the SATA interface cable. It is directly next to the power cable on the CD drive.
      FixBot'a Sor
      Yorum Ekle
    5. HP Envy 700-030qe CD Drive Replacement: adım 5, 1 resimden 1.
      • Now pull up and swing the mounting lever in. The lever closest to the front mounts the top drive slot, and the lever farther away mounts the bottom one.
      FixBot'a Sor
      Yorum Ekle
    6. HP Envy 700-030qe CD Drive Replacement: adım 6, 2 resimden 1. HP Envy 700-030qe CD Drive Replacement: adım 6, 2 resimden 2.
      • Now stand your desktop up and remove the 3 clips on the right side of the front panel.
      • Then pull the front panel off, pulling from the side that the clips are on.
      FixBot'a Sor
      Yorum Ekle
    7. HP Envy 700-030qe CD Drive Replacement: adım 7, 1 resimden 1.
      • Now you can pull the CD drive straight out of the casing!
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Yoav Rosenberg
396 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-9, Maness Fall 2015 Cal Poly, Team 5-9, Maness Fall 2015 üyesi
CPSU-MANESS-F15S5G9
4 Üyeler
50 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 27
Her zaman: 1,654
