Ana içeriğe geç
HP Envy 700-030qe Power Supply Replacement
Neye ihtiyacın var
  1. HP Envy 700-030qe Power Supply Replacement, Power Supply: adım 1, 3 resimden 1. HP Envy 700-030qe Power Supply Replacement, Power Supply: adım 1, 3 resimden 2. HP Envy 700-030qe Power Supply Replacement, Power Supply: adım 1, 3 resimden 3.
    • Make sure that you are wearing your anti-static wristband. This will prevent damaging any internal parts with any built up static electricity.
    • Unscrew the 10.5mm screw on the left of the desktop using your hand.
    • If it is too tight you may use a torx-head screwdriver or a flat-head screwdriver.
  2. HP Envy 700-030qe Power Supply Replacement: adım 2, 2 resimden 1. HP Envy 700-030qe Power Supply Replacement: adım 2, 2 resimden 2.
    • Remove the side panel by sliding it towards the back of the desktop and pulling up on it as shown.
  3. HP Envy 700-030qe Power Supply Replacement: adım 3, 1 resimden 1.
    • Remove the four 5mm screws holding the power supply in place with a T15 Torx screwdriver.
  4. HP Envy 700-030qe Power Supply Replacement: adım 4, 2 resimden 1. HP Envy 700-030qe Power Supply Replacement: adım 4, 2 resimden 2.
    • Undo the clasp which holds the power supply in place by pushing down on it.
    • Pull out the power supply up and towards you.
  5. HP Envy 700-030qe Power Supply Replacement: adım 5, 1 resimden 1.
    • Unplug the power cable going to the CD drive by pulling straight.
  6. HP Envy 700-030qe Power Supply Replacement: adım 6, 1 resimden 1.
    • Set aside the power supply on the left side of the computer.
  7. HP Envy 700-030qe Power Supply Replacement: adım 7, 1 resimden 1.
    • Unplug the SATA interface power cable going to the hard drive by pulling straight up.
  8. HP Envy 700-030qe Power Supply Replacement: adım 8, 1 resimden 1.
    • Unplug the power cable going to the mother board by pulling straight up.
  9. HP Envy 700-030qe Power Supply Replacement: adım 9, 1 resimden 1.
    • Unplug the power cable going to the fan by pulling straight up.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Yoav Rosenberg
321 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-9, Maness Fall 2015 Cal Poly, Team 5-9, Maness Fall 2015 üyesi
CPSU-MANESS-F15S5G9
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 35
Her zaman: 4,285
