Ana içeriğe geç
HP Envy 700-030qe Solid State Drive Replacement
Neye ihtiyacın var
    1. HP Envy 700-030qe Solid State Drive Replacement, Solid State Drive: adım 1, 1 resimden 1.
      • Before beginning, it is good to wear an anti-static wrist band to prevent electrical components from getting harmed.
      • Attach the anti-static wristband to your wrist, and clip the other end to an exposed piece of metal anywhere on the case.
      FixBot'a Sor
      Yorum Ekle
    2. HP Envy 700-030qe Solid State Drive Replacement: adım 2, 1 resimden 1.
      • Start by opening the device case by unscrewing the 10.5mm hand screw on the back of the computer.
      • If the hand screw is too tight, you may use the Torx T15 screwdriver to remove it.
      FixBot'a Sor
      Yorum Ekle
    3. HP Envy 700-030qe Solid State Drive Replacement: adım 3, 1 resimden 1.
      • Turn the computer onto its side to continue removing the case cover.
      • Slide the cover off by sliding it to the right.
      FixBot'a Sor
      Yorum Ekle
    4. HP Envy 700-030qe Solid State Drive Replacement: adım 4, 2 resimden 1. HP Envy 700-030qe Solid State Drive Replacement: adım 4, 2 resimden 2.
      • Locate the SSD inside the open case.
      • Unplug the SATA power cable from the hard drive by pulling straight up.
      FixBot'a Sor
      Yorum Ekle
    5. HP Envy 700-030qe Solid State Drive Replacement: adım 5, 1 resimden 1.
      • Finish disconnecting the hard drive by unplugging the black SATA interface cable by pulling up.
      FixBot'a Sor
      Yorum Ekle
    6. HP Envy 700-030qe Solid State Drive Replacement: adım 6, 1 resimden 1.
      • To remove the SSD and its casing, pull out on the side silver tab.
      • At the same time, pull up on the hard drive. It should slide out smoothly without much effort.
      FixBot'a Sor
      Yorum Ekle
    7. HP Envy 700-030qe Solid State Drive Replacement: adım 7, 1 resimden 1.
      • To completly remove the SSD from its casing, unscrew the four 5mm screws on opposite ends of the casing. Use a Torx T15 screw driver to accomplish this.
      • Notice that the screws to remove are the four screws inside the holes rather than the screws that are next to the holes.
      FixBot'a Sor
      Yorum Ekle
    8. HP Envy 700-030qe Solid State Drive Replacement: adım 8, 1 resimden 1.
      • Finally, slide the SSD out of the casing.
      FixBot'a Sor
      Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Chandler Warne
306 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 5-9, Maness Fall 2015 Cal Poly, Team 5-9, Maness Fall 2015 üyesi
CPSU-MANESS-F15S5G9
4 Üyeler
50 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 37
Her zaman: 3,127
