Ana içeriğe geç
HP Envy M6-1205DX Fan Replacement
Neye ihtiyacın var
  1. HP Envy M6-1205DX Fan Replacement, Battery: adım 1, 1 resimden 1.
    • Lay the device face down to begin.
  2. HP Envy M6-1205DX Fan Replacement: adım 2, 1 resimden 1.
    • Slide the release mechanism to the left to release the battery.
  3. HP Envy M6-1205DX Fan Replacement: adım 3, 2 resimden 1. HP Envy M6-1205DX Fan Replacement: adım 3, 2 resimden 2.
    • Remove the battery.
  4. HP Envy M6-1205DX Fan Replacement, Touchpad: adım 4, 1 resimden 1.
    • Using a Phillips #1, remove the 8 10.6mm screws.
    • Also using a Phillips #1, remove the 8.6mm screw.
  5. HP Envy M6-1205DX Fan Replacement: adım 5, 1 resimden 1.
    • Slide the center panel down to remove it.
  6. HP Envy M6-1205DX Fan Replacement: adım 6, 1 resimden 1.
    • Using a Phillips #1, remove the 3.5mm screw.
    • Our computer did not come with a hard drive so you should have one in the empty hole. We have marked where we believe the screws will be in orange.
    • Using a Phillips #1, remove the four 10.6mm screws.
  7. HP Envy M6-1205DX Fan Replacement: adım 7, 1 resimden 1.
    • Pull the disk drive out to remove it.
  8. HP Envy M6-1205DX Fan Replacement: adım 8, 2 resimden 1. HP Envy M6-1205DX Fan Replacement: adım 8, 2 resimden 2.
    • Using a Phillips #1, remove the two 2.4mm screws.
  9. HP Envy M6-1205DX Fan Replacement: adım 9, 2 resimden 1. HP Envy M6-1205DX Fan Replacement: adım 9, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Flip the black tab up on the clamp that holds the ribbon cable in place.
    • Pull the cable back with your fingers or a pair of tweezers.
  10. HP Envy M6-1205DX Fan Replacement: adım 10, 2 resimden 1. HP Envy M6-1205DX Fan Replacement: adım 10, 2 resimden 2.
    • Flip the computer back over
    • Use the plastic opening tool to pry the keyboard up .
  11. HP Envy M6-1205DX Fan Replacement: adım 11, 3 resimden 1. HP Envy M6-1205DX Fan Replacement: adım 11, 3 resimden 2. HP Envy M6-1205DX Fan Replacement: adım 11, 3 resimden 3.
    • Carefully lift the keyboard up.
    • Flip up the black tab holding the large ribbon cable down.
    • Push both sides of the small white tab forward to release the small ribbon cable.
    • Pull both the cables out to remove them.
    • Remove the keyboard.
  12. HP Envy M6-1205DX Fan Replacement: adım 12, 3 resimden 1. HP Envy M6-1205DX Fan Replacement: adım 12, 3 resimden 2. HP Envy M6-1205DX Fan Replacement: adım 12, 3 resimden 3.
    • Flip the small white tab up to release the ribbon cable.
    • Pull to remove.
    • Repeat the same steps for the other cable.
  13. HP Envy M6-1205DX Fan Replacement: adım 13, 1 resimden 1.
    • Using a Phillips #1, remove the four 5.6mm silver screws.
  14. HP Envy M6-1205DX Fan Replacement: adım 14, 2 resimden 1. HP Envy M6-1205DX Fan Replacement: adım 14, 2 resimden 2.
    • Use the plastic opening tool to pry the face plate off the rest of the frame.
    • Once you pry all of the snaps up lift the face plate off.
  15. HP Envy M6-1205DX Fan Replacement, Fan: adım 15, 1 resimden 1.
    • Using a Phillips #1, remove the two 10.6 mm screws.
    • Gently pull back on on the cable to unplug it.
  16. HP Envy M6-1205DX Fan Replacement: adım 16, 1 resimden 1.
    • Pull the fan out to remove it.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 5,697
