Ana içeriğe geç
HP Envy M6-1205DX Palm Rest Replacement
Neye ihtiyacın var
  1. HP Envy M6-1205DX Palm Rest Replacement, Battery: adım 1, 1 resimden 1.
    • Lay the device face down to begin.
  2. HP Envy M6-1205DX Palm Rest Replacement: adım 2, 1 resimden 1.
    • Slide the release mechanism to the left to release the battery.
  3. HP Envy M6-1205DX Palm Rest Replacement: adım 3, 2 resimden 1. HP Envy M6-1205DX Palm Rest Replacement: adım 3, 2 resimden 2.
    • Remove the battery.
  4. HP Envy M6-1205DX Palm Rest Replacement, Back Panel: adım 4, 1 resimden 1.
    • Using a Phillips #1 screwdriver, remove the 8.6 mm screw.
  5. HP Envy M6-1205DX Palm Rest Replacement: adım 5, 1 resimden 1.
    • Slide the center panel down to remove it.
  6. HP Envy M6-1205DX Palm Rest Replacement, Palm Rest: adım 6, 1 resimden 1.
    • Set the computer facing upwards again.
    • Using the plastic opening tool gently pry the keyboard up.
  7. HP Envy M6-1205DX Palm Rest Replacement: adım 7, 3 resimden 1. HP Envy M6-1205DX Palm Rest Replacement: adım 7, 3 resimden 2. HP Envy M6-1205DX Palm Rest Replacement: adım 7, 3 resimden 3.
    • Flip the white tab on the large ribbon cable upward. Gently pull the large ribbon cable out to remove it.
    • Gently pull the small ribbon cable out to remove it.
  8. HP Envy M6-1205DX Palm Rest Replacement: adım 8, 3 resimden 1. HP Envy M6-1205DX Palm Rest Replacement: adım 8, 3 resimden 2. HP Envy M6-1205DX Palm Rest Replacement: adım 8, 3 resimden 3.
    • Gently pull the tension cable to remove it.
  9. HP Envy M6-1205DX Palm Rest Replacement: adım 9, 1 resimden 1.
    • Using a Phillips #1 screwdriver, remove the four 5.6 mm silver screws.
  10. HP Envy M6-1205DX Palm Rest Replacement: adım 10, 2 resimden 1. HP Envy M6-1205DX Palm Rest Replacement: adım 10, 2 resimden 2.
    • Use the plastic opening tool to loosen the palm rest from the frame.
    • Once you pry all of the snaps up lift off the palm rest.
Sonuç
Ryan Hatton
634 İtibar
5 adet Kılavuz yazıldı
Ekip
IUPUI, Team S2-G2, Wilson Fall 2019 IUPUI, Team S2-G2, Wilson Fall 2019 üyesi
IUPUI-WILSON-F19S2G2
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 281
