Ana içeriğe geç
HP Envy M6-1205DX RAM Replacement
Neye ihtiyacın var
  1. HP Envy M6-1205DX RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Lay the device face down to begin.
  2. HP Envy M6-1205DX RAM Replacement: adım 2, 1 resimden 1.
    • Slide the release mechanism to the left to release the battery.
  3. HP Envy M6-1205DX RAM Replacement: adım 3, 2 resimden 1. HP Envy M6-1205DX RAM Replacement: adım 3, 2 resimden 2.
    • Remove the battery.
  4. HP Envy M6-1205DX RAM Replacement, Back Panel: adım 4, 1 resimden 1.
    • Using a Phillips #1 screwdriver, remove the 8.6 mm screw.
  5. HP Envy M6-1205DX RAM Replacement: adım 5, 1 resimden 1.
    • Slide the center panel down to remove it.
  6. HP Envy M6-1205DX RAM Replacement, RAM: adım 6, 1 resimden 1.
    • To release the RAM push out on the two release mechanisms holding it down.
  7. HP Envy M6-1205DX RAM Replacement: adım 7, 1 resimden 1.
    • Lift gently up on the RAM to position it for removal.
  8. HP Envy M6-1205DX RAM Replacement: adım 8, 1 resimden 1.
    • Gently pull the RAM out of its slot.
  9. HP Envy M6-1205DX RAM Replacement: adım 9, 1 resimden 1.
    • Upon removing the first stick of RAM you will find a second RAM stick located beneath it.
    • Release the second RAM stick by pushing the two release mechanisms outward.
    • Pull the RAM stick out.
Sonuç
Ryan Hatton
634 İtibar
5 adet Kılavuz yazıldı
Ekip
IUPUI, Team S2-G2, Wilson Fall 2019 IUPUI, Team S2-G2, Wilson Fall 2019 üyesi
IUPUI-WILSON-F19S2G2
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 244
