Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
This guide is to help you replace your fan on the HP Envy Sleekbook m6-k010dx.
  1. Remove the twelve 9 mm Phillips #00 screws.
    • Remove the twelve 9 mm Phillips #00 screws.
  2. Use the plastic opening tool and your hands to remove the bottom cover. Use the plastic opening tool and your hands to remove the bottom cover.
    • Use the plastic opening tool and your hands to remove the bottom cover.
  3. Disconnect the battery power cable from the motherboard.
    • Disconnect the battery power cable from the motherboard.
  4. Nintendo Switch Kit'leri
    Oyuna geri dönmek için hızlı bir düzeltme
    Switch Kit'leri Satın Al
  5. Remove the six 6 mm Phillips #00 screws from the battery.
    • Remove the six 6 mm Phillips #00 screws from the battery.
  6. Lift the battery out of the laptop. Lift the battery out of the laptop.
    • Lift the battery out of the laptop.
  7. Remove two 3mm Phillips #00 screws from the fan.
    • Remove two 3mm Phillips #00 screws from the fan.
  8. Disconnect the fan cable by pulling it out of the motherboard socket. Disconnect the fan cable by pulling it out of the motherboard socket.
    • Disconnect the fan cable by pulling it out of the motherboard socket.
  9. Lift the fan upwards to remove it from the computer.
    • Lift the fan upwards to remove it from the computer.
Sonuç
Ana Novo
347 İtibar
2 adet Kılavuz yazıldı
Takım
USF Tampa, Team S1-G4, Nance Spring 2018 USF Tampa, Team S1-G4, Nance Spring 2018 üyesi
USFT-NANCE-S18S1G4
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 308
