Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Use the plastic opening tool and your hands to remove the bottom cover.
Disconnect the battery power cable from the motherboard.
Remove the six 6 mm Phillips #00 screws from the battery.
Disconnect the fan cable by pulling it out of the motherboard socket.
Flip up the black tab on the ZIF connector and pull the blue and white flex cable connecting the touchpad to the motherboard.
Remove three 3mm Phillips #00 screws from the SD card board.
Remove the SD card board.
In order to remove the RAM, pull each silver clip (one at a time) away from the RAM.
The RAM chip should pop up. Gently remove the RAM from the motherboard.
Remove four 3mm Phillips #00 screws from the heatsink.
Lift the heat sink out from the device and set it aside.
Remove the black and white antenna wires from the Wi-Fi card.
Remove the two 3mm Phillips #00 screws that secure the speaker to the device.
Remove the four 4mm Phillips #00 screws from the bracket.
Locate the speaker cable connecting the speaker to the audio board. Gently tug on this cable to dislodge. Set the speaker aside.
Remove the two 3mm Phillips #00 screws that secure the RJ-45 module.
Lift the white tab on the ZIF connector and pull the ribbon cable out.
Remove the 3mm Phillips #00 screw connecting the chip to the housing.
Lift up silver bracket.
Lift up the white flap on the ZIF connector and remove the purple ribbon cable.
Remove the cover for the RM-45 port.
Gently lift and remove the chip from its housing.
Remove the 4mm Phillips #00 screws.
Remove the silver 3mm Phillips 3 mm screw.
Lift all three black flaps in the ZIF connectors and remove the attached ribbon cables.
Use your hand and gently remove the connector to the back up battery for the motherboard.
Remove the four 4mm Phillips #00 screws from the motherboard.
Lift the board at an angle and pull outwards to dislodge it from the device.
Remove the thirteen silver 3mm Phillips #00 screws that secure the keyboard to the frame.
Lift up the keyboard from the bracket and pull outwards to remove the keyboard from the device.
2 farklı kişi bu kılavuzu tamamladı.
