Ana içeriğe geç
Giriş
If your computer turns on but nothing is displayed on the LCD, it might be time to replace it. This guide will walk you through each step.
  1. Remove the twelve 9 mm Phillips #00 screws.
    • Remove the twelve 9 mm Phillips #00 screws.
  2. Use the plastic opening tool and your hands to remove the bottom cover. Use the plastic opening tool and your hands to remove the bottom cover.
    • Use the plastic opening tool and your hands to remove the bottom cover.
  3. Disconnect the battery power cable from the motherboard.
    • Disconnect the battery power cable from the motherboard.
  4. Remove the six 6 mm Phillips #00 screws from the battery.
    • Remove the six 6 mm Phillips #00 screws from the battery.
  5. Lift the battery out of the laptop. Lift the battery out of the laptop.
    • Lift the battery out of the laptop.
  6. Remove the stickers from the bottom left and right corner of the device with a plastic opening tool. Remove the stickers from the bottom left and right corner of the device with a plastic opening tool.
    • Remove the stickers from the bottom left and right corner of the device with a plastic opening tool.
  7. Remove the two 2.5mm Phillips #00 screws found underneath the previously removed stickers.
    • Remove the two 2.5mm Phillips #00 screws found underneath the previously removed stickers.
  8. Use the plastic opening tool to pry the bezel free from the LCD housing. Use the plastic opening tool to pry the bezel free from the LCD housing. Use the plastic opening tool to pry the bezel free from the LCD housing.
    • Use the plastic opening tool to pry the bezel free from the LCD housing.
  9. Remove the four 2.5mm Phillips #00 screws located in each corner of the LCD screen. Remove the four 2.5mm Phillips #00 screws located in each corner of the LCD screen.
    • Remove the four 2.5mm Phillips #00 screws located in each corner of the LCD screen.
  10. Use the plastic opening tool to remove the LCD screen from its housing. Lay the LCD screen flat on the keyboard.
    • Use the plastic opening tool to remove the LCD screen from its housing.
    • Lay the LCD screen flat on the keyboard.
  11. Disconnect the cable which connects the LCD to the motherboard.
    • Disconnect the cable which connects the LCD to the motherboard.
    • Pul the LCD screen out.
Sonuç
codi whittaker
433 İtibar
3 adet Kılavuz yazıldı
Takım
USF Tampa, Team S1-G4, Nance Spring 2018 USF Tampa, Team S1-G4, Nance Spring 2018 üyesi
USFT-NANCE-S18S1G4
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 17
Her zaman: 186
