Ana içeriğe geç
HP Envy Sleekbook m6-k010dx TouchPad Replacement
Neye ihtiyacın var
  1. HP Envy Sleekbook m6-k010dx TouchPad Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the twelve 9 mm Phillips #00 screws.
  2. HP Envy Sleekbook m6-k010dx TouchPad Replacement: adım 2, 2 resimden 1. HP Envy Sleekbook m6-k010dx TouchPad Replacement: adım 2, 2 resimden 2.
    • Use the plastic opening tool and your hands to remove the bottom cover.
  3. HP Envy Sleekbook m6-k010dx TouchPad Replacement: adım 3, 1 resimden 1.
    • Disconnect the battery power cable from the motherboard.
  4. HP Envy Sleekbook m6-k010dx TouchPad Replacement: adım 4, 1 resimden 1.
    • Remove the six 6 mm Phillips #00 screws from the battery.
  5. HP Envy Sleekbook m6-k010dx TouchPad Replacement: adım 5, 2 resimden 1. HP Envy Sleekbook m6-k010dx TouchPad Replacement: adım 5, 2 resimden 2.
    • Lift the battery out of the laptop.
  6. HP Envy Sleekbook m6-k010dx TouchPad Replacement, TouchPad: adım 6, 1 resimden 1.
    • Lift the white tab on the ZIF connector to unlock the ribbon cable.
    • Pull the ribbon cable out of the ZIF connector.
  7. HP Envy Sleekbook m6-k010dx TouchPad Replacement: adım 7, 1 resimden 1.
    • Remove the seven 3mm Phillips #00 screws from the trackpad.
  8. HP Envy Sleekbook m6-k010dx TouchPad Replacement: adım 8, 1 resimden 1.
    • Use the plastic opening tool to lift the touchpad up and pull out to remove.
Sonuç
codi whittaker
508 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G4, Nance Spring 2018 USF Tampa, Team S1-G4, Nance Spring 2018 üyesi
USFT-NANCE-S18S1G4
4 Üyeler
15 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 18
Her zaman: 629
