Ana içeriğe geç
HP Envy TouchSmart 15 CMOS Battery Replacement
Neye ihtiyacın var
  1. HP Envy TouchSmart 15 CMOS Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Press the battery release tab and the battery will pop up.
  2. HP Envy TouchSmart 15 CMOS Battery Replacement: adım 2, 1 resimden 1.
    • Remove the battery from the laptop, it will come out easily.
  3. HP Envy TouchSmart 15 CMOS Battery Replacement, Accessory Plate: adım 3, 2 resimden 1. HP Envy TouchSmart 15 CMOS Battery Replacement, Accessory Plate: adım 3, 2 resimden 2.
    • Remove the single screw holding the accessory plate. This is a PH0 2.0x2.5 screw.
  4. HP Envy TouchSmart 15 CMOS Battery Replacement: adım 4, 3 resimden 1. HP Envy TouchSmart 15 CMOS Battery Replacement: adım 4, 3 resimden 2. HP Envy TouchSmart 15 CMOS Battery Replacement: adım 4, 3 resimden 3.
    • Pry the accessory plate up from the back of the laptop by applying force upwards where the screw was removed.
  5. HP Envy TouchSmart 15 CMOS Battery Replacement, CMOS Battery: adım 5, 3 resimden 1. HP Envy TouchSmart 15 CMOS Battery Replacement, CMOS Battery: adım 5, 3 resimden 2. HP Envy TouchSmart 15 CMOS Battery Replacement, CMOS Battery: adım 5, 3 resimden 3.
    • Remove the screw from the wireless adapter with a PH0 screwdriver then move the adapter out of the way to access the CMOS battery.
  6. HP Envy TouchSmart 15 CMOS Battery Replacement: adım 6, 1 resimden 1.
    • Use a plastic or metal spudger to release the CMOS battery from the clips.
  7. HP Envy TouchSmart 15 CMOS Battery Replacement: adım 7, 2 resimden 1. HP Envy TouchSmart 15 CMOS Battery Replacement: adım 7, 2 resimden 2.
    • Remove the battery from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Robert Patterson
1.442 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-6, Sullivan Fall 2015 USF Tampa, Team 2-6, Sullivan Fall 2015 üyesi
USFT-SULLIVAN-F15S2G6
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 21
Her zaman: 7,687
