Giriş
Upon boot up, the computer may read a “CMOS checksum error,” or date and time keep getting reset. If this is the error you are receiving you should replace your CMOS Battery.
Neye ihtiyacın var
Remove the single screw holding the accessory plate. This is a PH0 2.0x2.5 screw.
Remove the screw from the wireless adapter with a PH0 screwdriver then move the adapter out of the way to access the CMOS battery.
Bir başkası bu kılavuzu tamamladı.
