Ana içeriğe geç
HP Envy TouchSmart 15 Wireless Adapter Replacement
Neye ihtiyacın var
  1. HP Envy TouchSmart 15 Wireless Adapter Replacement, Battery: adım 1, 1 resimden 1.
    • Press the battery release tab and the battery will pop up.
    FixBot'a Sor
    Yorum Ekle
  2. HP Envy TouchSmart 15 Wireless Adapter Replacement: adım 2, 1 resimden 1.
    • Remove the battery from the laptop, it will come out easily.
    FixBot'a Sor
    Yorum Ekle
  3. HP Envy TouchSmart 15 Wireless Adapter Replacement, Accessory Plate: adım 3, 2 resimden 1. HP Envy TouchSmart 15 Wireless Adapter Replacement, Accessory Plate: adım 3, 2 resimden 2.
    • Remove the single screw holding the accessory plate. This is a PH0 2.0x2.5 screw.
    FixBot'a Sor
    Yorum Ekle
  4. HP Envy TouchSmart 15 Wireless Adapter Replacement: adım 4, 3 resimden 1. HP Envy TouchSmart 15 Wireless Adapter Replacement: adım 4, 3 resimden 2. HP Envy TouchSmart 15 Wireless Adapter Replacement: adım 4, 3 resimden 3.
    • Pry the accessory plate up from the back of the laptop by applying force upwards where the screw was removed.
    FixBot'a Sor
    Yorum Ekle
  5. HP Envy TouchSmart 15 Wireless Adapter Replacement, Wireless Adapter: adım 5, 2 resimden 1. HP Envy TouchSmart 15 Wireless Adapter Replacement, Wireless Adapter: adım 5, 2 resimden 2.
    • Remove the screw with PH 0 screwdriver that is holding the wireless adapter in. This is PM 2.0x2.5 screws.
    FixBot'a Sor
    Yorum Ekle
  6. HP Envy TouchSmart 15 Wireless Adapter Replacement: adım 6, 3 resimden 1. HP Envy TouchSmart 15 Wireless Adapter Replacement: adım 6, 3 resimden 2. HP Envy TouchSmart 15 Wireless Adapter Replacement: adım 6, 3 resimden 3.
    • Hold the wireless adapter and gently remove the white and black wires from it. The connectors will come out straight up.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Robert Patterson
1.494 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-6, Sullivan Fall 2015 USF Tampa, Team 2-6, Sullivan Fall 2015 üyesi
USFT-SULLIVAN-F15S2G6
4 Üyeler
10 adet Kılavuz yazıldı
1Rehber Yorum
Hi, I use this exact laptop but my wifi card was changed and it didn’t come with Bluetooth so i wanted to know if this
https://www.aliexpress.com/item/Dual-Ban...
can work for me and if its OK to buy it. Thanks
temidayoabayomizannu - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 41
Her zaman: 3,627
