Ana içeriğe geç
HP Envy TouchSmart 15 Wireless Adapter Replacement
Neye ihtiyacın var
  1. HP Envy TouchSmart 15 Wireless Adapter Replacement, Battery: adım 1, 1 resimden 1.
    • Press the battery release tab and the battery will pop up.
  2. HP Envy TouchSmart 15 Wireless Adapter Replacement: adım 2, 1 resimden 1.
    • Remove the battery from the laptop, it will come out easily.
  3. HP Envy TouchSmart 15 Wireless Adapter Replacement, Accessory Plate: adım 3, 2 resimden 1. HP Envy TouchSmart 15 Wireless Adapter Replacement, Accessory Plate: adım 3, 2 resimden 2.
    • Remove the single screw holding the accessory plate. This is a PH0 2.0x2.5 screw.
  4. HP Envy TouchSmart 15 Wireless Adapter Replacement: adım 4, 3 resimden 1. HP Envy TouchSmart 15 Wireless Adapter Replacement: adım 4, 3 resimden 2. HP Envy TouchSmart 15 Wireless Adapter Replacement: adım 4, 3 resimden 3.
    • Pry the accessory plate up from the back of the laptop by applying force upwards where the screw was removed.
  5. HP Envy TouchSmart 15 Wireless Adapter Replacement, Wireless Adapter: adım 5, 2 resimden 1. HP Envy TouchSmart 15 Wireless Adapter Replacement, Wireless Adapter: adım 5, 2 resimden 2.
    • Remove the screw with PH 0 screwdriver that is holding the wireless adapter in. This is PM 2.0x2.5 screws.
  6. HP Envy TouchSmart 15 Wireless Adapter Replacement: adım 6, 3 resimden 1. HP Envy TouchSmart 15 Wireless Adapter Replacement: adım 6, 3 resimden 2. HP Envy TouchSmart 15 Wireless Adapter Replacement: adım 6, 3 resimden 3.
    • Hold the wireless adapter and gently remove the white and black wires from it. The connectors will come out straight up.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Robert Patterson
1.442 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-6, Sullivan Fall 2015 USF Tampa, Team 2-6, Sullivan Fall 2015 üyesi
USFT-SULLIVAN-F15S2G6
4 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
Hi, I use this exact laptop but my wifi card was changed and it didn’t come with Bluetooth so i wanted to know if this
https://www.aliexpress.com/item/Dual-Ban...
can work for me and if its OK to buy it. Thanks
temidayoabayomizannu - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 16
Her zaman: 3,146
