Ana içeriğe geç
HP Envy TouchSmart 4-1215dx Display Replacement
Neye ihtiyacın var
  1. HP Envy TouchSmart 4-1215dx Display Replacement, Display: adım 1, 1 resimden 1.
    • Remove both 3 mm screws at the bottom of the display using a Phillips #0 screwdriver.
  2. HP Envy TouchSmart 4-1215dx Display Replacement: adım 2, 2 resimden 1. HP Envy TouchSmart 4-1215dx Display Replacement: adım 2, 2 resimden 2.
    • Using an iFixit opening tool, pry the screen from the back panel.
    • Remove the back panel.
  3. HP Envy TouchSmart 4-1215dx Display Replacement: adım 3, 1 resimden 1.
    • Close the laptop so the front is facing you.
    • Remove the four 3 mm screws from the two brackets at the front using a Phillips #0 screwdriver.
    • Remove the brackets.
  4. HP Envy TouchSmart 4-1215dx Display Replacement: adım 4, 3 resimden 1. HP Envy TouchSmart 4-1215dx Display Replacement: adım 4, 3 resimden 2. HP Envy TouchSmart 4-1215dx Display Replacement: adım 4, 3 resimden 3.
    • Remove the 3 mm screws from the back brackets using a Phillips #0 screwdriver.
    • Remove the 1 mm screws with a Phillips #00 screwdriver.
    • Lift up the display until the brackets are sticking straight up.
  5. HP Envy TouchSmart 4-1215dx Display Replacement: adım 5, 1 resimden 1.
    • Peel off the aluminum tape located at the top of the display.
  6. HP Envy TouchSmart 4-1215dx Display Replacement: adım 6, 2 resimden 1. HP Envy TouchSmart 4-1215dx Display Replacement: adım 6, 2 resimden 2.
    • Disconnect the ribbon cable and peel off the connected tape from the display.
  7. HP Envy TouchSmart 4-1215dx Display Replacement: adım 7, 2 resimden 1. HP Envy TouchSmart 4-1215dx Display Replacement: adım 7, 2 resimden 2.
    • Lift the display up separately from the screen.
    • Peel off the orange tape at the bottom of the display connecting to the laptop.
  8. HP Envy TouchSmart 4-1215dx Display Replacement: adım 8, 1 resimden 1.
    • Lift up the display.
    • If your display is cracked or shattered, you should tape up the effected parts in order to avoid injury.
Sonuç
Isaac York
157 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 221
