Ana içeriğe geç
HP Envy TouchSmart 4-1215dx Motherboard Replacement
Neye ihtiyacın var
  1. HP Envy TouchSmart 4-1215dx Motherboard Replacement, Back Panel Assembly: adım 1, 2 resimden 1. HP Envy TouchSmart 4-1215dx Motherboard Replacement, Back Panel Assembly: adım 1, 2 resimden 2.
    • Remove the thirteen Phillips #0 screws.
  2. HP Envy TouchSmart 4-1215dx Motherboard Replacement: adım 2, 2 resimden 1. HP Envy TouchSmart 4-1215dx Motherboard Replacement: adım 2, 2 resimden 2.
    • Pull the panel up and off to remove from the laptop.
  3. HP Envy TouchSmart 4-1215dx Motherboard Replacement, Battery: adım 3, 2 resimden 1. HP Envy TouchSmart 4-1215dx Motherboard Replacement, Battery: adım 3, 2 resimden 2.
    • Unplug the battery from the motherboard.
  4. HP Envy TouchSmart 4-1215dx Motherboard Replacement: adım 4, 2 resimden 1. HP Envy TouchSmart 4-1215dx Motherboard Replacement: adım 4, 2 resimden 2.
    • Remove the three Phillips #0 screws from the battery.
    • Pull the battery out of the laptop.
  5. HP Envy TouchSmart 4-1215dx Motherboard Replacement, Fan: adım 5, 1 resimden 1.
    • Unplug the fan from the motherboard.
  6. HP Envy TouchSmart 4-1215dx Motherboard Replacement: adım 6, 2 resimden 1. HP Envy TouchSmart 4-1215dx Motherboard Replacement: adım 6, 2 resimden 2.
    • Remove the four Phillips #0 screws holding in the fan.
    • Pull out the fan.
  7. HP Envy TouchSmart 4-1215dx Motherboard Replacement, Wi-Fi Card: adım 7, 2 resimden 1. HP Envy TouchSmart 4-1215dx Motherboard Replacement, Wi-Fi Card: adım 7, 2 resimden 2.
    • Remove the single screw from the Wi-Fi card using a Phillips #0 screwdriver.
    • Pull the Wi-Fi card out of its slot.
  8. HP Envy TouchSmart 4-1215dx Motherboard Replacement, Heat Sink: adım 8, 1 resimden 1.
    • Remove four screws from the heat sink using a Phillips #0 screwdriver.
  9. HP Envy TouchSmart 4-1215dx Motherboard Replacement: adım 9, 1 resimden 1.
    • Gently lift the heat sink from the motherboard.
  10. HP Envy TouchSmart 4-1215dx Motherboard Replacement, Motherboard: adım 10, 1 resimden 1.
    • Remove the remaining from the motherboard with a Phillips #0 screwdriver.
  11. HP Envy TouchSmart 4-1215dx Motherboard Replacement: adım 11, 3 resimden 1. HP Envy TouchSmart 4-1215dx Motherboard Replacement: adım 11, 3 resimden 2. HP Envy TouchSmart 4-1215dx Motherboard Replacement: adım 11, 3 resimden 3.
    • Disconnect the remaining cables from the motherboard by gently tugging on the pull tabs or the edges of the connectors that sit in the terminals.
  12. HP Envy TouchSmart 4-1215dx Motherboard Replacement: adım 12, 2 resimden 1. HP Envy TouchSmart 4-1215dx Motherboard Replacement: adım 12, 2 resimden 2.
    • Gently lift the motherboard from the housing to remove it from the laptop.
Sonuç
Cassie Hunter
97 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 137
