Giriş
This is a complete guide that will direct you in removing and replacing the motherboard of an HP Envy TouchSmart 4-1215dx.
The motherboard typically houses the important components such as the CPU, GPU, connectors for the network card, and RAM slots. It plays a huge part in supplying power to every part of the computer. If you have tried replacing other components and your laptop still is not functioning, it's possible that the board is damaged and may need replaced.
Neye ihtiyacın var
Remove the single screw from the Wi-Fi card using a Phillips #0 screwdriver.
Pull the Wi-Fi card out of its slot.
Remove the remaining from the motherboard with a Phillips #0 screwdriver.
