Ana içeriğe geç
HP Envy TouchSmart m7 k010dx KeyBoard Replacement
Neye ihtiyacın var
  1. HP Envy TouchSmart m7 k010dx KeyBoard Replacement, Battery: adım 1, 3 resimden 1. HP Envy TouchSmart m7 k010dx KeyBoard Replacement, Battery: adım 1, 3 resimden 2. HP Envy TouchSmart m7 k010dx KeyBoard Replacement, Battery: adım 1, 3 resimden 3.
    • Turn your computer over so that the bottom is facing up.
    • Slide the left black switch towards center.
    • You should see an unlock image exposed to the left of switch if done correctly.
  2. HP Envy TouchSmart m7 k010dx KeyBoard Replacement: adım 2, 2 resimden 1. HP Envy TouchSmart m7 k010dx KeyBoard Replacement: adım 2, 2 resimden 2.
    • Slide the right black switch towards center to release the battery.
  3. HP Envy TouchSmart m7 k010dx KeyBoard Replacement: adım 3, 2 resimden 1. HP Envy TouchSmart m7 k010dx KeyBoard Replacement: adım 3, 2 resimden 2.
    • Pivot the loose edge of the battery closes to you by pushing it toward the back of the computer.
    • The battery should slide out freely.
    • If battery is not pivoted before sliding out, you risk breaking interlocking tabs on the battery or computer.
  4. HP Envy TouchSmart m7 k010dx KeyBoard Replacement, Keyboard: adım 4, 3 resimden 1. HP Envy TouchSmart m7 k010dx KeyBoard Replacement, Keyboard: adım 4, 3 resimden 2. HP Envy TouchSmart m7 k010dx KeyBoard Replacement, Keyboard: adım 4, 3 resimden 3.
    • With the computer turned over use a nylon spudger to pry the rectangular pads off to reveal two hidden screws.
    • Using a Phillips #0 screwdriver, remove the screw that is beneath the black rubber pad, as well as the other holding down the black corner plastic pieces on both the left and right sides.
  5. HP Envy TouchSmart m7 k010dx KeyBoard Replacement: adım 5, 1 resimden 1.
    • Use a plastic opening tool to pop the corners off by wedging between casing. Do this for both legs as depicted in the picture.
  6. HP Envy TouchSmart m7 k010dx KeyBoard Replacement: adım 6, 3 resimden 1. HP Envy TouchSmart m7 k010dx KeyBoard Replacement: adım 6, 3 resimden 2. HP Envy TouchSmart m7 k010dx KeyBoard Replacement: adım 6, 3 resimden 3.
    • Using the Phillips #0 screwdriver, remove the screw in the center of the computer, and to the right of the Beats logo.
    • Use your fingernails to pull out the optical drive. It will have some resistance to start, but will come out easily afterwards.
  7. HP Envy TouchSmart m7 k010dx KeyBoard Replacement: adım 7, 2 resimden 1. HP Envy TouchSmart m7 k010dx KeyBoard Replacement: adım 7, 2 resimden 2.
    • Using a JIS #00 screwdriver, remove the two screws that were revealed when the optical drive was removed.
    • Use a Phillips #0 screwdriver to remove all screws that are visible on the bottom.
    • There is an oval tab near the center of the laptop, use the flat end of a nylon spudger to wedge it free to reveal another Phillips #0 screw.
  8. HP Envy TouchSmart m7 k010dx KeyBoard Replacement: adım 8, 3 resimden 1. HP Envy TouchSmart m7 k010dx KeyBoard Replacement: adım 8, 3 resimden 2. HP Envy TouchSmart m7 k010dx KeyBoard Replacement: adım 8, 3 resimden 3.
    • Open up the laptop and set it down normally.
    • Use a credit card or spudger to wedge between the top and bottom keyboard casing.
    • Slide the card all the way around the laptop, making sure to pop free all tabs.
  9. HP Envy TouchSmart m7 k010dx KeyBoard Replacement: adım 9, 2 resimden 1. HP Envy TouchSmart m7 k010dx KeyBoard Replacement: adım 9, 2 resimden 2.
    • Place the computer on the backside of the screen, so that the bottom of it is pointing up into the air.
    • You may want to place a rag over the screen so that if the front panel touches it while being removed, no damage is caused.
    • Carefully begin to separate the top case from the bottom case, as if you are opening it like a book from the edge nearest the touch pad.
  10. HP Envy TouchSmart m7 k010dx KeyBoard Replacement: adım 10, 3 resimden 1. HP Envy TouchSmart m7 k010dx KeyBoard Replacement: adım 10, 3 resimden 2. HP Envy TouchSmart m7 k010dx KeyBoard Replacement: adım 10, 3 resimden 3.
    • The two panels are connected with 4 flexible electrical ribbon strips. The ribbon strips have a locking tab that will need to be disengaged prior to removal. Using fingers, begin by removing the two strips nearest to the opening.
    • Picture 3 shows the tab unlocked
  11. HP Envy TouchSmart m7 k010dx KeyBoard Replacement: adım 11, 2 resimden 1. HP Envy TouchSmart m7 k010dx KeyBoard Replacement: adım 11, 2 resimden 2.
    • With the two panels now separated, you can see the other two strips towards the back of the computer. With finger, carefully release each strip from the locking tab.
    • Once all are unplugged, carefully remove the top case.
Sonuç
Owen Ou
443 İtibar
4 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 1,467
