Ana içeriğe geç
HP Envy Touchsmart m6-k125dx Touch Screen Replacement
Neye ihtiyacın var
  1. HP Envy Touchsmart m6-k125dx Touch Screen Replacement, Touch Screen: adım 1, 1 resimden 1.
    • Open the laptop.
    • Remove black tabs at bottom left and right corners and remove the two M2.5x2.5 screws behind the black tabs with the J0 screwdriver.
  2. HP Envy Touchsmart m6-k125dx Touch Screen Replacement: adım 2, 2 resimden 1. HP Envy Touchsmart m6-k125dx Touch Screen Replacement: adım 2, 2 resimden 2.
    • Insert pick between the black plastic screen panel and the silver plastic exterior case on the side of the device.
    • Slide pick around the border of the screen panel while keeping the pick between the mentioned panel and exterior case.
    • Repeat previous two steps until exterior case is removed. Pry with minimal force if necessary.
  3. HP Envy Touchsmart m6-k125dx Touch Screen Replacement: adım 3, 3 resimden 1. HP Envy Touchsmart m6-k125dx Touch Screen Replacement: adım 3, 3 resimden 2. HP Envy Touchsmart m6-k125dx Touch Screen Replacement: adım 3, 3 resimden 3.
    • Remove the front panel from the rest of the device and set it aside.
    • Remove the ten M2.5x2.5 screws with the J0 screwdriver.
    • Remove the eight M2.0x2.0 screws with the J0 screwdriver.
  4. HP Envy Touchsmart m6-k125dx Touch Screen Replacement: adım 4, 3 resimden 1. HP Envy Touchsmart m6-k125dx Touch Screen Replacement: adım 4, 3 resimden 2. HP Envy Touchsmart m6-k125dx Touch Screen Replacement: adım 4, 3 resimden 3.
    • Flip hinges down and away from the rest of the panel.
    • Remove the four M2.5x2.5 screws with the J0 screwdriver.
    • Move 4 pieces of black tape across the bottom of the panel and any other accessory tape.
    • Disconnect the display cable connector that is located at the bottom right of the panel by pulling lightly.
  5. HP Envy Touchsmart m6-k125dx Touch Screen Replacement: adım 5, 1 resimden 1.
    • Slowly lift the screen away from the touch screen front panel to remove.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Madison Velchek
151 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S14-G14, Wilson Spring 2019 IUPUI, Team S14-G14, Wilson Spring 2019 üyesi
IUPUI-WILSON-S19S14G14
4 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 867
