Giriş
The following step-by-step guide serves to show the correct way of replacing the Bluetooth Module on the HP Envy Ultrabook 4-1015dx Computer. A broken or faulty Bluetooth module can be identified through incorrect or lack of function of the PC’s normal Bluetooth capabilities. The steps below should be followed carefully to preserve the quality of the computer and not cause additional damages.
The equipment required for this repair is a new Bluetooth module for the HP Envy Device. The tools required to complete the replacement of the Bluetooth module are available to buy below.
Neye ihtiyacın var
Make sure that the device is turned off and that all external devices are removed.
Remove the tape holding the power connector cable and loosen the cable from the routing channel to gain access to the bluetooth module.
