Ana içeriğe geç
HP Envy Ultrabook 4-1015dx Cooling Fan Replacement
Neye ihtiyacın var
  1. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure that the device is turned off and that all external devices are removed.
  2. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: adım 2, 1 resimden 1.
    • Flip the device over so that the back plate is facing upwards.
  3. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: adım 3, 2 resimden 1. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: adım 3, 2 resimden 2.
    • Using a small (size 0) Phillips head screwdriver, remove the twelve 5.5 mm external Phillips head screws that connect the back plate to the device.
    • Make sure to set the screws aside in a safe place so that you do not lose them, as they will be needed to reattach the backplate later.
  4. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: adım 4, 2 resimden 1. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: adım 4, 2 resimden 2.
    • Using the plastic opening tool, gently pry off the back plate from the device.
  5. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: adım 5, 2 resimden 1. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: adım 5, 2 resimden 2.
    • The large black box with the white warning images is the battery.
    • Move the ribbon cable so that it is no longer on top of the battery.
  6. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: adım 6, 2 resimden 1. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: adım 6, 2 resimden 2.
    • Using a small (size 0) Phillips head screwdriver, remove the three 3.5 mm Phillips head internal screws that hold the battery in place.
    • Make sure not to lose these internal screws; they will later be used to reattach the battery.
  7. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: adım 7, 2 resimden 1. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: adım 7, 2 resimden 2.
    • Lift up the battery and remove it from the slot as shown.
  8. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: adım 8, 3 resimden 1. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: adım 8, 3 resimden 2. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: adım 8, 3 resimden 3.
    • Use the plastic opening tool to disconnect the battery cable.
  9. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: adım 9, 1 resimden 1.
    • Lift up the battery and remove it from the device.
  10. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement, Cooling Fan: adım 10, 2 resimden 1. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement, Cooling Fan: adım 10, 2 resimden 2.
    • Remove the screws that secure the top cover of the fan.
  11. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: adım 11, 1 resimden 1.
    • Lift the fan up and remove it gently.
  12. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: adım 12, 1 resimden 1.
    • Remove the fan cable with the plastic opening tool.
  13. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: adım 13, 1 resimden 1.
    • Remove the fan from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Eve Wyman
139 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G3, Valliere Fall 2018 UMass Dartmouth, Team S1-G3, Valliere Fall 2018 üyesi
UMASSD-VALLIERE-F18S1G3
5 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 4
Her zaman: 171
