Ana içeriğe geç
HP Envy Ultrabook 4-1043cl Cooling Fan Replacement
Neye ihtiyacın var
  1. HP Envy Ultrabook 4-1043cl Cooling Fan Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop over so the bottom is facing you.
  2. HP Envy Ultrabook 4-1043cl Cooling Fan Replacement: adım 2, 2 resimden 1. HP Envy Ultrabook 4-1043cl Cooling Fan Replacement: adım 2, 2 resimden 2.
    • Remove twelve 7.5 mm screws by using the Phillips #00 screwdriver.
  3. HP Envy Ultrabook 4-1043cl Cooling Fan Replacement: adım 3, 1 resimden 1.
    • Use plastic opening tool to remove the back cover.
    • You might want to remove it slowly and gently because the back cover is very thin and fragile.
  4. HP Envy Ultrabook 4-1043cl Cooling Fan Replacement: adım 4, 2 resimden 1. HP Envy Ultrabook 4-1043cl Cooling Fan Replacement: adım 4, 2 resimden 2.
    • Remove three 4.2mm screws by using the Phillips #00 screwdriver.
  5. HP Envy Ultrabook 4-1043cl Cooling Fan Replacement: adım 5, 2 resimden 1. HP Envy Ultrabook 4-1043cl Cooling Fan Replacement: adım 5, 2 resimden 2.
    • Disconnect the battery cable from the motherboard and remove the battery from the device.
  6. HP Envy Ultrabook 4-1043cl Cooling Fan Replacement, Cooling Fan: adım 6, 2 resimden 1. HP Envy Ultrabook 4-1043cl Cooling Fan Replacement, Cooling Fan: adım 6, 2 resimden 2.
    • Remove one 4.2mm screw at the bottom right corner by using the Phillips #00 screwdriver.
  7. HP Envy Ultrabook 4-1043cl Cooling Fan Replacement: adım 7, 2 resimden 1. HP Envy Ultrabook 4-1043cl Cooling Fan Replacement: adım 7, 2 resimden 2.
    • Disconnect the fan from the motherboard and remove it from the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 219
