Ana içeriğe geç
HP Envy Ultrabook 4-1043cl Hard Drive Replacement
Neye ihtiyacın var
  1. HP Envy Ultrabook 4-1043cl Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop over so the bottom is facing you.
  2. HP Envy Ultrabook 4-1043cl Hard Drive Replacement: adım 2, 2 resimden 1. HP Envy Ultrabook 4-1043cl Hard Drive Replacement: adım 2, 2 resimden 2.
    • Remove twelve 7.5 mm screws by using the Phillips #00 screwdriver.
  3. HP Envy Ultrabook 4-1043cl Hard Drive Replacement: adım 3, 1 resimden 1.
    • Use plastic opening tool to remove the back cover.
    • You might want to remove it slowly and gently because the back cover is very thin and fragile.
  4. HP Envy Ultrabook 4-1043cl Hard Drive Replacement: adım 4, 2 resimden 1. HP Envy Ultrabook 4-1043cl Hard Drive Replacement: adım 4, 2 resimden 2.
    • Remove three 4.2mm screws by using the Phillips #00 screwdriver.
  5. HP Envy Ultrabook 4-1043cl Hard Drive Replacement: adım 5, 2 resimden 1. HP Envy Ultrabook 4-1043cl Hard Drive Replacement: adım 5, 2 resimden 2.
    • Disconnect the battery cable from the motherboard and remove the battery from the device.
  6. HP Envy Ultrabook 4-1043cl Hard Drive Replacement, Hard Drive: adım 6, 3 resimden 1. HP Envy Ultrabook 4-1043cl Hard Drive Replacement, Hard Drive: adım 6, 3 resimden 2. HP Envy Ultrabook 4-1043cl Hard Drive Replacement, Hard Drive: adım 6, 3 resimden 3.
    • The hard drive is in the bottom right corner of the device which is packed by a silver metal shell.
    • Use a Phillips #00 screwdriver to remove the four 4.0 mm screws securing the hard drive to the top cover.
  7. HP Envy Ultrabook 4-1043cl Hard Drive Replacement: adım 7, 2 resimden 1. HP Envy Ultrabook 4-1043cl Hard Drive Replacement: adım 7, 2 resimden 2.
  8. HP Envy Ultrabook 4-1043cl Hard Drive Replacement: adım 8, 2 resimden 1. HP Envy Ultrabook 4-1043cl Hard Drive Replacement: adım 8, 2 resimden 2.
    • Pull the hard disk drive out of the connector socket and remove it from the device.
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 562
