Ana içeriğe geç
HP Envy Ultrabook 4-1043cl RAM Replacement
Neye ihtiyacın var
  1. HP Envy Ultrabook 4-1043cl RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop over so the bottom is facing you.
  2. HP Envy Ultrabook 4-1043cl RAM Replacement: adım 2, 2 resimden 1. HP Envy Ultrabook 4-1043cl RAM Replacement: adım 2, 2 resimden 2.
    • Remove twelve 7.5 mm screws by using the Phillips #00 screwdriver.
  3. HP Envy Ultrabook 4-1043cl RAM Replacement: adım 3, 1 resimden 1.
    • Use plastic opening tool to remove the back cover.
    • You might want to remove it slowly and gently because the back cover is very thin and fragile.
  4. HP Envy Ultrabook 4-1043cl RAM Replacement: adım 4, 2 resimden 1. HP Envy Ultrabook 4-1043cl RAM Replacement: adım 4, 2 resimden 2.
    • Remove three 4.2mm screws by using the Phillips #00 screwdriver.
  5. HP Envy Ultrabook 4-1043cl RAM Replacement: adım 5, 2 resimden 1. HP Envy Ultrabook 4-1043cl RAM Replacement: adım 5, 2 resimden 2.
    • Disconnect the battery cable from the motherboard and remove the battery from the device.
  6. HP Envy Ultrabook 4-1043cl RAM Replacement, RAM: adım 6, 3 resimden 1. HP Envy Ultrabook 4-1043cl RAM Replacement, RAM: adım 6, 3 resimden 2. HP Envy Ultrabook 4-1043cl RAM Replacement, RAM: adım 6, 3 resimden 3.
    • The RAM lies in the middle-right side of the device.
    • Use your fingers and push the two clips outwards to release the RAM stick.
  7. HP Envy Ultrabook 4-1043cl RAM Replacement: adım 7, 1 resimden 1.
    • Remove the RAM from the device.
  8. HP Envy Ultrabook 4-1043cl RAM Replacement: adım 8, 3 resimden 1. HP Envy Ultrabook 4-1043cl RAM Replacement: adım 8, 3 resimden 2. HP Envy Ultrabook 4-1043cl RAM Replacement: adım 8, 3 resimden 3.
    • Repeat the previous two steps to remove any other RAM sticks.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 282
