Ana içeriğe geç
HP Envy X2-15-C001Dx Wi-Fi Card Replacement
Neye ihtiyacın var
  1. HP Envy X2-15-C001Dx Wi-Fi Card Replacement, Back Panel: adım 1, 1 resimden 1.
    • Place the laptop face down on a table.
  2. HP Envy X2-15-C001Dx Wi-Fi Card Replacement: adım 2, 2 resimden 1. HP Envy X2-15-C001Dx Wi-Fi Card Replacement: adım 2, 2 resimden 2.
    • Lift up the back stand.
  3. HP Envy X2-15-C001Dx Wi-Fi Card Replacement: adım 3, 2 resimden 1. HP Envy X2-15-C001Dx Wi-Fi Card Replacement: adım 3, 2 resimden 2.
    • Remove the five screws from the bottom of the back plate using a Phillips #1 screwdriver.
  4. HP Envy X2-15-C001Dx Wi-Fi Card Replacement: adım 4, 1 resimden 1.
    • Remove four screws from the back stand hinges using a Phillips #1 screwdriver.
  5. HP Envy X2-15-C001Dx Wi-Fi Card Replacement: adım 5, 2 resimden 1. HP Envy X2-15-C001Dx Wi-Fi Card Replacement: adım 5, 2 resimden 2.
    • Remove the hinges and the back stand from the laptop.
  6. HP Envy X2-15-C001Dx Wi-Fi Card Replacement: adım 6, 1 resimden 1.
    • Use a spudger to remove the thin panel where the back stand was.
  7. HP Envy X2-15-C001Dx Wi-Fi Card Replacement: adım 7, 1 resimden 1.
    • Remove the screws from the back panel using a Phillips #1 screwdriver.
  8. HP Envy X2-15-C001Dx Wi-Fi Card Replacement: adım 8, 2 resimden 1. HP Envy X2-15-C001Dx Wi-Fi Card Replacement: adım 8, 2 resimden 2.
    • Remove two side screws using a Phillips #1 screwdriver.
  9. HP Envy X2-15-C001Dx Wi-Fi Card Replacement: adım 9, 2 resimden 1. HP Envy X2-15-C001Dx Wi-Fi Card Replacement: adım 9, 2 resimden 2.
    • Pry apart the base from the screen by going around the entire perimeter with an opening tool.
  10. HP Envy X2-15-C001Dx Wi-Fi Card Replacement: adım 10, 2 resimden 1. HP Envy X2-15-C001Dx Wi-Fi Card Replacement: adım 10, 2 resimden 2.
    • Remove the back panel from the laptop.
  11. HP Envy X2-15-C001Dx Wi-Fi Card Replacement, Wi-Fi Card: adım 11, 1 resimden 1.
    • Remove the screw holding the Wi-Fi card using a Phillips #1 screwdriver.
  12. HP Envy X2-15-C001Dx Wi-Fi Card Replacement: adım 12, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Disconnect the white coaxial cable connected to the Wi-Fi card using a pair of tweezers.
  13. HP Envy X2-15-C001Dx Wi-Fi Card Replacement: adım 13, 1 resimden 1.
    • Disconnect the black coaxial cable connected to the Wi-Fi card using a pair of tweezers.
  14. HP Envy X2-15-C001Dx Wi-Fi Card Replacement: adım 14, 1 resimden 1.
    • Pull out the Wi-Fi card out of its slot to remove it from the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Dylan Hathaway
686 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-6, Sinclaire Fall 2021 UMass Dartmouth, Team 2-6, Sinclaire Fall 2021 üyesi
UMASSD-SINCLAIRE-F21S2G6
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 91
