Ana içeriğe geç
HP Envy dv6-7363cl Fan Replacement
Neye ihtiyacın var
  1. HP Envy dv6-7363cl Fan Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the device upside-down so that its bottom is facing up.
  2. HP Envy dv6-7363cl Fan Replacement: adım 2, 1 resimden 1.
    • Push the lever underneath the battery to the left.
  3. HP Envy dv6-7363cl Fan Replacement: adım 3, 2 resimden 1. HP Envy dv6-7363cl Fan Replacement: adım 3, 2 resimden 2.
    • Lift the battery up out of its socket.
  4. HP Envy dv6-7363cl Fan Replacement, Fan: adım 4, 1 resimden 1.
    • Remove the circled screws from the back panel.
  5. HP Envy dv6-7363cl Fan Replacement: adım 5, 1 resimden 1.
    • Lift and remove the back panel of the device.
  6. HP Envy dv6-7363cl Fan Replacement: adım 6, 3 resimden 1. HP Envy dv6-7363cl Fan Replacement: adım 6, 3 resimden 2. HP Envy dv6-7363cl Fan Replacement: adım 6, 3 resimden 3.
    • Flip the laptop back over and carefully pry the keyboard frame out of the device.
  7. HP Envy dv6-7363cl Fan Replacement: adım 7, 3 resimden 1. HP Envy dv6-7363cl Fan Replacement: adım 7, 3 resimden 2. HP Envy dv6-7363cl Fan Replacement: adım 7, 3 resimden 3.
    • Lift the keyboard out of the device
    • Carefully remove ribbon cables.
  8. HP Envy dv6-7363cl Fan Replacement: adım 8, 3 resimden 1. HP Envy dv6-7363cl Fan Replacement: adım 8, 3 resimden 2. HP Envy dv6-7363cl Fan Replacement: adım 8, 3 resimden 3.
    • Flip device onto its back
    • Remove disk tray and circled screw.
  9. HP Envy dv6-7363cl Fan Replacement: adım 9, 2 resimden 1. HP Envy dv6-7363cl Fan Replacement: adım 9, 2 resimden 2.
    • Flip device right-side-up and remove ribbon cables from plastic cover beneath keyboard. Remove plastic cover from device.
  10. HP Envy dv6-7363cl Fan Replacement: adım 10, 3 resimden 1. HP Envy dv6-7363cl Fan Replacement: adım 10, 3 resimden 2. HP Envy dv6-7363cl Fan Replacement: adım 10, 3 resimden 3.
    • Disconnect red cord from DVD drive and remove DVD drive.
  11. HP Envy dv6-7363cl Fan Replacement: adım 11, 3 resimden 1. HP Envy dv6-7363cl Fan Replacement: adım 11, 3 resimden 2. HP Envy dv6-7363cl Fan Replacement: adım 11, 3 resimden 3.
    • Remove circled screws.
  12. HP Envy dv6-7363cl Fan Replacement: adım 12, 2 resimden 1. HP Envy dv6-7363cl Fan Replacement: adım 12, 2 resimden 2.
    • Disconnect red and white cords from blue circuit board.
  13. HP Envy dv6-7363cl Fan Replacement: adım 13, 3 resimden 1. HP Envy dv6-7363cl Fan Replacement: adım 13, 3 resimden 2. HP Envy dv6-7363cl Fan Replacement: adım 13, 3 resimden 3.
    • Gently pull circled pieces from their holsters.
  14. HP Envy dv6-7363cl Fan Replacement: adım 14, 2 resimden 1. HP Envy dv6-7363cl Fan Replacement: adım 14, 2 resimden 2.
    • Turn device onto its back and remove circled screws from Wi-Fi card.
    • Flip device back over and unscrew disk reader
  15. HP Envy dv6-7363cl Fan Replacement: adım 15, 1 resimden 1.
    • Remove circled screws from blue circuit board and lift fan assembly out of device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
dylananthony
564 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G5, Bernier Spring 2018 UMass Dartmouth, Team S2-G5, Bernier Spring 2018 üyesi
UMASSD-BERNIER-S18S2G5
3 Üyeler
4 adet Kılavuz yazıldı
2 Yorum
My laptop is a slightly different model and everything provided by the author is likely accurate for their model. I only mention this to caution that your repair may be slightly different depending on your specific model. Mine was different in a few areas though held mostly true with my dv6t-7000. Cheers!
zabadoo - Yanıt
Salom menga shu modeldagi kompyuterni ustgi qopqogʻini topib pochta qila olasizmi iloji boʻlsa iltimos nomerim +998991768069 shu nomerga telfon qib bogʻlanishiz mumkin men bilan
Shamsullo Quzratov - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 30
Her zaman: 4,371
