Ana içeriğe geç
HP Envy dv6-7363cl Keyboard Replacement
Neye ihtiyacın var
  1. HP Envy dv6-7363cl Keyboard Replacement, Keyboard: adım 1, 1 resimden 1.
    • Start by opening the laptop
  2. HP Envy dv6-7363cl Keyboard Replacement: adım 2, 3 resimden 1. HP Envy dv6-7363cl Keyboard Replacement: adım 2, 3 resimden 2. HP Envy dv6-7363cl Keyboard Replacement: adım 2, 3 resimden 3.
    • Pry off the keyboard retainer slowly working your way around the board to prevent damage
  3. HP Envy dv6-7363cl Keyboard Replacement: adım 3, 2 resimden 1. HP Envy dv6-7363cl Keyboard Replacement: adım 3, 2 resimden 2.
    • Carefully pull up on the key board there will be 2 ribbon strips holding it attached to the key board
  4. HP Envy dv6-7363cl Keyboard Replacement: adım 4, 2 resimden 1. HP Envy dv6-7363cl Keyboard Replacement: adım 4, 2 resimden 2.
    • Pull up on the two grey tabs that hold the ribbon cable into the connector. Then remove the keyboard.
Sonuç
austin urban
159 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G5, Bernier Spring 2018 UMass Dartmouth, Team S2-G5, Bernier Spring 2018 üyesi
UMASSD-BERNIER-S18S2G5
3 Üyeler
4 adet Kılavuz yazıldı
Bir Yorum
Salom shu kampyuterni ustgi qopqogʻi kerak topishni iloji bormi
Shamsullo Quzratov - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 502
