Ana içeriğe geç
HP Envy dv6-7363cl Wi-fi Card Replacement
Neye ihtiyacın var
  1. HP Envy dv6-7363cl Wi-fi Card Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the device upside-down so that its bottom is facing up.
  2. HP Envy dv6-7363cl Wi-fi Card Replacement: adım 2, 1 resimden 1.
    • Push the lever underneath the battery to the left.
  3. HP Envy dv6-7363cl Wi-fi Card Replacement: adım 3, 2 resimden 1. HP Envy dv6-7363cl Wi-fi Card Replacement: adım 3, 2 resimden 2.
    • Lift the battery up out of its socket.
  4. HP Envy dv6-7363cl Wi-fi Card Replacement, Wi-Fi Card: adım 4, 1 resimden 1.
    • After removing the battery, remove the circled screw.
  5. HP Envy dv6-7363cl Wi-fi Card Replacement: adım 5, 1 resimden 1.
    • Remove the back cover.
  6. HP Envy dv6-7363cl Wi-fi Card Replacement: adım 6, 1 resimden 1.
    • With the back cover removed, locate the Wi-Fi card which is positioned next to the Beats logo.
  7. HP Envy dv6-7363cl Wi-fi Card Replacement: adım 7, 2 resimden 1. HP Envy dv6-7363cl Wi-fi Card Replacement: adım 7, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Carefully remove gold-headed, black wires from Wi-Fi card with tweezers.
  8. HP Envy dv6-7363cl Wi-fi Card Replacement: adım 8, 2 resimden 1. HP Envy dv6-7363cl Wi-fi Card Replacement: adım 8, 2 resimden 2.
    • After removing wires, remove circled screws from card.
    • Note: Laptop shown only has one screw holding in Wi-Fi card. Some models may have both.
  9. HP Envy dv6-7363cl Wi-fi Card Replacement: adım 9, 2 resimden 1. HP Envy dv6-7363cl Wi-fi Card Replacement: adım 9, 2 resimden 2.
    • Wi-Fi card will raise out of device when screw is removed.
    • Gently pull card to the right to remove from device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
dylananthony
564 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G5, Bernier Spring 2018 UMass Dartmouth, Team S2-G5, Bernier Spring 2018 üyesi
UMASSD-BERNIER-S18S2G5
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 364
