Ana içeriğe geç
HP Envy dv7 Hard Drive Replacement
Neye ihtiyacın var
  1. HP Envy dv7 Hard Drive  Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Slide the switch shown in the circle above and remove the battery from its housing. No screws are required to remove this part, and the battery should come out with little to no effort.
    FixBot'a Sor
    Yorum Ekle
  2. HP Envy dv7 Hard Drive  Replacement: adım 2, 1 resimden 1.
    • After removing the battery, find the center screw and unscrew it using a #1 Phillips head screwdriver until it will not unscrew any further.
    • This screw is not supposed to come out, so do not be frustrated when you are not able to take it out.
    FixBot'a Sor
    Yorum Ekle
  3. HP Envy dv7 Hard Drive  Replacement: adım 3, 1 resimden 1.
    • After undoing the center screw, the back cover will be able to slide off of the computer and you will have access to the inside.
    FixBot'a Sor
    Yorum Ekle
  4. HP Envy dv7 Hard Drive  Replacement: adım 4, 1 resimden 1.
    • To unfasten the hard drive's casing, there are two 3mm screws that you need to undo circled above. These screws require a Phillips #1 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  5. HP Envy dv7 Hard Drive  Replacement: adım 5, 1 resimden 1.
    • After the screws are removed, the casing will slide to the left and then up. Make sure that the cable that connects it to the computer is as intact as possible.
    FixBot'a Sor
    Yorum Ekle
  6. HP Envy dv7 Hard Drive  Replacement: adım 6, 2 resimden 1. HP Envy dv7 Hard Drive  Replacement: adım 6, 2 resimden 2.
    • To gain access to the actual hard drive, there are two screws located on either long side of the casing that need to be undone. These screws are 3mm long and require a Phillips #1 Screwdriver to undo.
    FixBot'a Sor
    Yorum Ekle
  7. HP Envy dv7 Hard Drive  Replacement: adım 7, 1 resimden 1.
    • After the screws around the casing are removed, the casing will slide off opposite to the connector. From here, grip the connector that is connected to the hard drive and gently pull to remove it.
    • From here, you are free to implement whatever hard drive unit you want to, just make sure to verify that the hard drive is compatible with your computer.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
1Rehber Yorum
I am looking for a hdd replacement with Windows 10 or 11 on it for my HP ENVY DV7 The present drive has Win 8 bout it’s not coming up
Yes Child - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 31
Her zaman: 2,096
