Ana içeriğe geç
HP Envy dv7t-7200 Optical Disc Drive Replacement
Neye ihtiyacın var
  1. HP Envy dv7t-7200 Optical Disc Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the power off and disconnect all cables and cords from the laptop.
    • Place the computer on its top on a flat surface with the hinges facing away from you.
  2. HP Envy dv7t-7200 Optical Disc Drive Replacement: adım 2, 3 resimden 1. HP Envy dv7t-7200 Optical Disc Drive Replacement: adım 2, 3 resimden 2. HP Envy dv7t-7200 Optical Disc Drive Replacement: adım 2, 3 resimden 3.
    • Slide the battery release latch to the left which is located on the right-hand side of the battery.
  3. HP Envy dv7t-7200 Optical Disc Drive Replacement: adım 3, 1 resimden 1.
    • Tilt the battery away from you and lift out.
  4. HP Envy dv7t-7200 Optical Disc Drive Replacement, Service Cover: adım 4, 1 resimden 1.
    • Using a Phillips #01 screwdriver, remove the Phillips PM2.5×5.5 screw on the service cover.
    • This screw does not come out of the service cover completely once loosened.
  5. HP Envy dv7t-7200 Optical Disc Drive Replacement: adım 5, 2 resimden 1. HP Envy dv7t-7200 Optical Disc Drive Replacement: adım 5, 2 resimden 2.
    • Slide the service cover toward the front of the laptop.
    • Lift the service cover to remove it from the laptop.
  6. HP Envy dv7t-7200 Optical Disc Drive Replacement, Optical Disc Drive: adım 6, 1 resimden 1.
    • Remove the Phillips PM2.5×4.0 screw that attaches the optical drive to the laptop.
  7. HP Envy dv7t-7200 Optical Disc Drive Replacement: adım 7, 2 resimden 1. HP Envy dv7t-7200 Optical Disc Drive Replacement: adım 7, 2 resimden 2.
    • Press the tab with a metal spudger that is located next to the screw to release the optical drive.
  8. HP Envy dv7t-7200 Optical Disc Drive Replacement: adım 8, 2 resimden 1. HP Envy dv7t-7200 Optical Disc Drive Replacement: adım 8, 2 resimden 2.
    • Slide the disk drive out of the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Krystal
882 İtibar
8 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S3-G3, Liner Fall 2017 UW Tacoma, Team S3-G3, Liner Fall 2017 üyesi
UWT-LINER-F17S3G3
5 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 128
