Ana içeriğe geç
HP Envy m6-1105dx WLAN Card Replacement
Neye ihtiyacın var
  1. HP Envy m6-1105dx WLAN Card Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the computer completely off.
    • Disconnect any devices you have on it.
    • Turn the computer upside down on a flat surface.
  2. HP Envy m6-1105dx WLAN Card Replacement: adım 2, 1 resimden 1.
    • Push the battery release latch with one hand.
    • Grab the battery with the other hand.
    • Lift out on an angle.
  3. HP Envy m6-1105dx WLAN Card Replacement, WLAN Card: adım 3, 1 resimden 1.
    • Release the screw in the center of the service cover.
    • Slide the battery release latch and pull cover towards you.
    • Lift cover off.
  4. HP Envy m6-1105dx WLAN Card Replacement: adım 4, 2 resimden 1. HP Envy m6-1105dx WLAN Card Replacement: adım 4, 2 resimden 2.
    • Use a JIS #0 screwdriver to unscrew the small cover where the WLAN card is.
    • The screw does not come out all the way so unscrew it as far as you can then try to life the cover.
  5. HP Envy m6-1105dx WLAN Card Replacement: adım 5, 3 resimden 1. HP Envy m6-1105dx WLAN Card Replacement: adım 5, 3 resimden 2. HP Envy m6-1105dx WLAN Card Replacement: adım 5, 3 resimden 3.
    • Use a plastic opening tool to gently disconnect the WLAN antenna cables.
  6. HP Envy m6-1105dx WLAN Card Replacement: adım 6, 2 resimden 1. HP Envy m6-1105dx WLAN Card Replacement: adım 6, 2 resimden 2.
    • Remove the two PM2.0×3.0 screws that secure the WLAN module to the base using the JIS #0 screwdriver.
    • Using two fingers, grab the sides of the WLAN card and slowly pull it out.
Sonuç
Ian Mwalago
303 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G5, Valliere Fall 2018 UMass Dartmouth, Team S1-G5, Valliere Fall 2018 üyesi
UMASSD-VALLIERE-F18S1G5
5 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 601
