Ana içeriğe geç
HP Envy m6-1225dx Optical Drive Replacement
Neye ihtiyacın var
  1. HP Envy m6-1225dx Optical Drive Replacement, Optical Drive: adım 1, 1 resimden 1.
    • Flip the laptop over onto it's top with the back facing you
  2. HP Envy m6-1225dx Optical Drive Replacement: adım 2, 3 resimden 1. HP Envy m6-1225dx Optical Drive Replacement: adım 2, 3 resimden 2. HP Envy m6-1225dx Optical Drive Replacement: adım 2, 3 resimden 3.
    • Pull the slide release tab to the left to free the battery.
    • Once the slide release is all the way over, a red icon should be visible.
    • As you pull the tab, the bottom edge of the battery should start to come up.
  3. HP Envy m6-1225dx Optical Drive Replacement: adım 3, 1 resimden 1.
    • Remove the battery
  4. HP Envy m6-1225dx Optical Drive Replacement: adım 4, 2 resimden 1. HP Envy m6-1225dx Optical Drive Replacement: adım 4, 2 resimden 2.
    • Remove the center screw using a Phillips #1 screwdriver.
  5. HP Envy m6-1225dx Optical Drive Replacement: adım 5, 2 resimden 1. HP Envy m6-1225dx Optical Drive Replacement: adım 5, 2 resimden 2.
    • Move the battery slide release latch to the side while pulling the service cover forward.
    • Pull the service cover straight up and out to remove.
  6. HP Envy m6-1225dx Optical Drive Replacement: adım 6, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove the single screw holding the optical drive
  7. HP Envy m6-1225dx Optical Drive Replacement: adım 7, 2 resimden 1. HP Envy m6-1225dx Optical Drive Replacement: adım 7, 2 resimden 2.
    • Use a spudger to apply pressure to the tab, while simultaneously pulling out the optical drive.
    • While the images show the tab being pushed out with a screwdriver, we recommend using an ESD-safe instrument instead!
  8. HP Envy m6-1225dx Optical Drive Replacement: adım 8, 1 resimden 1.
    • Pull the optical drive out of the base of the laptop.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 162
