Neye ihtiyacın var
There are 12 phillips head screws which need to be unscrewed before removing the backplate of the laptop.
The fan is located here. You will need to remove three screws in order to lift the fan out from the motherboard.
You will need a Phillips 00 size screwdriver to remove the screws.
Bir başkası bu kılavuzu tamamladı.
