Ana içeriğe geç
HP Envy m6-k022dx RAM Replacement
Neye ihtiyacın var
  1. HP Envy m6-k022dx RAM Replacement, Lower Case: adım 1, 1 resimden 1.
    • There are 12 phillips head screws which need to be unscrewed before removing the backplate of the laptop.
  2. HP Envy m6-k022dx RAM Replacement: adım 2, 1 resimden 1.
    • Next, use a size PH1 Philips head screw driver to remove the screws.
  3. HP Envy m6-k022dx RAM Replacement: adım 3, 1 resimden 1.
    • Then, use a prying tool to help uncouple the backplate.
  4. HP Envy m6-k022dx RAM Replacement: adım 4, 1 resimden 1.
    • Finally, use both hands to lift up and take off the back plate of the computer.
  5. HP Envy m6-k022dx RAM Replacement, RAM: adım 5, 1 resimden 1.
    • The RAM sticks are located in the right upper corner of the laptop of the laptop.
  6. HP Envy m6-k022dx RAM Replacement: adım 6, 1 resimden 1.
    • There are two clips holding each RAM stick in place; one on each side of each stick.
    • Gently pull each clips outwards, away from the RAM sticks. They will easily unclip from the RAM.
  7. HP Envy m6-k022dx RAM Replacement: adım 7, 1 resimden 1.
    • Grab the top of the RAM stick and pull directly up, towards the outer edge of the laptop.
    • The RAM sticks will slide out from their slots relatively easily. They are now ready to be replaced.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Anthony Stubbs
182 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S13-G6, Cagle Spring 2017 USF Tampa, Team S13-G6, Cagle Spring 2017 üyesi
USFT-CAGLE-S17S13G6
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 21
Her zaman: 1,246
